Green LED lights up whenever.
Red LED when the battery voltage descends near 10 volts.
4538 generates the first and second sample, the width of the samples is 50 usec in both cases.
Try to explain what little I understand. These are approximate values, and I mention it for information.
556 generates the pulse of adjustable transmison alrrededor of 300 Hz with a pulse width also adjustable, which is not the maximum value, I adjusted between 100 and 200 usec.
The first sample pulse is generated after the transmission TX, this is adjustable between 30 and 150 usec. with a 4538.
The second sample is generated with another 4538 from 100 to 700 usec.
4066 are the keys, some are used for integration of samples and other functions I have not quite understand.
Maybe someone on the forum, can give a better explanation of the functioning of the Delta Pulse therico.
Regards, Jose
Delta Pulse
sorry for more question please help me to understand
i did'nt know how circuit work such what compare pulse length and reflect pulse in the circuit what function of 4538 and 4066 ic sorry for question but i can't understand ?
IRF740 IS HOT
HI
I HAVE BUILD DELTA2 BUT HI NOT WORKS THE IRF740 IS VERY HOT MORE DOESN'T NOSE
BEST REGARDS
THANK YOU
P
thanks jose i will check ( zener and transistor turn on the LED display) but this make any error in circuit or just for display ?Originally posted by Jose View PostHi Amel
Check the zener and transistor turn on the LED display.
The function of damping resistance is to avoid oscillations in the coil, its value is critical and depends on the technical characteristics of the coil, whether or not IRF740 and the diode between the inductor.
You have to experiment with different settings to achieve better sensitivity.
Shielding is usually not necessary in the Delta of the pulse, which was not designed for low delays.
Anyway, I can recommend Scotch tape N24, if you want to shield the coil.
I do not work with aluminum tape or graphite.
refers to
Joseph
i did'nt know how circuit work such what compare the pulse and reflect pulse in the circuit what function of 4538 and 4066 ic sorry for question but i can understand ?
Hi Amel
refers to
Joseph
i build delta pulse and i have problem
hi
first problem that the green and red led are light when connect 12 v
what the problem and need help to explain the function of damping resistor the value i use is 680 ohm
my coil is 31 turn with 0.4 mm and 19 diameter ask can i make shielded with aluminium foil and plastic case
i wait to help my and thanks
Hello Freedan3dOriginally posted by freedan3d View PostHi pigeon
yes this pcb and componnents are correct
it work very well
Its hex limited in on/off only
i solved this counter in pim-1 whit hex manipilation
it is not very important
ill try to make another delta pulse pcb and i can start again
best regards
freedan 3d
The card "discriminator rar". Correct?
thanks
Jose
it work very well
best regards
freedan 3d
HI FREEDAN3D
THANK YOU VERY MUCH
GOOD LUCK
BESR REDARDS
Hi pigeonOriginally posted by pigeon View PostHI
I NOT INTERESTED IN HEX I WAN TO NOW IF THE PCB AND COMPONENTS ARE CORRECTE
THANK YOU
BEST REGARDS
it work very well
best regards
freedan 3d
Lcd
Can LCD be added to any delta pulse .I have a delta pulse and would like to add lcd
HIOriginally posted by szucs_g View PostPI really do not think the detectors are renowned for their skills for the selection. The depth sensitivity is good.
I do not think DP - LCD selects any metal. The original HEX file can not run it. Replaces the mechanical indicator (status bar). Works for me, but I do not expect her selection of metal.
THANK YOU
BEST REGARDS
Originally posted by Jose View PostApparently, the discriminator module "discriminator rar" published more ago, is a demo that can be executed 200 times, as can be seen in the Turkish forum.
The bars give a rough idea of metal detected.
Jose
http://www.teknolojiekibi.com/index1.html
Me too it appears on the LCD. (Without welcome words)
It seems to me that this is not the same as the Turkish solution. I think it's no discriminator.
