Originally posted by VUJO
Delta Pulse
because they are being used in the SAT (self auto tuning) stage and have to have ESR low loss. yes, they are hight voltage - 150-250V. no, this does not mean.
The question for the kt 315
Why are the capacitors C16 and C25, which are the integrator circuit of such a large raster? Does this mean that the high operating voltage?
Apocalypto, I promise you you will get the NEW FRESH board FIRST!Originally posted by apocalypto View PostWe are waiting for the new pcb from kt315, everyone should access to informations please share it
Cordialy
all are in the process.
all the bestAttached Files
You will be buying the finished PCB board? Need to get together and agree who and how many will buy a card, and put the price on them
Informations
Cordialy
ok....you can help me by attach some photos of the output on the oscilloscope at some points ....and if they are not the same with me ...so the problem at this point.
Hi amr muhamed
You did not specify the problems?
How I do and I do not know?
j.
i can't find the problems..... may be there are components burned.... i want to compare the output with your circuit
hi jap .... thanks for your answer... i am amr and work with amel ... if you finish your circuit.... i want the output at some point on the oscilloscope to know the problems with us .Originally posted by jap View PostDear amel
-rang 25cm use 4x8tu
-Small coil used to detect Small size of metal like Coins.
best time
j.
