Delta Pulse
  • Orbit
    I do not understand?
  • Jose
    [ATTACH]27558[/ATTACH]
    Orbita, referred to with this?
    Jose
  • kt315
    top side
  • Orbit
    GEOTECH SERBIA English version.rar
  • pigeon
    hi kt315
    this pcb is correct. this is my best i'm still a beginner
    thank you
    best time
    P.
Name:	pcb delta pulse k315 ok.png
  • Baterista
    hello Baterista, new PCB is based on this bulgarin design you attached. all that I see and have to add I added, all improvements, cooper pours (polygons), optimal tracing, etc. I added tantalum caps on bottom side too people could be learn to solder SMD. I especcially do not do a design in SMD because I noticed very small folks may solder SMD components, while I want to make PCB more adaptive and simple for beginners in electronics.
    Thanks kt315, this new layout seems very good. I also agree with the "DIP" methodology, for me get SMD components is very difficult.
  • Davor
    Mechanical stress is a good reason in favour of through hole design. I also tend to avoid tantalum for it's morally problematic origins - if I can help it.
  • kt315
  • Baterista
    PCB revision
    [ATTACH]27543[/ATTACH]
    Hello Kt315, some time I rode the Delta Pulse, based PCB posted by you, very good, working perfectly.
    This new PCB has performance improvements over the other?
  • pigeon
    PCB revision
    thank you very much for this new version but where is the pcb file to print.
  • kt315
    PCB revision
  • kt315
    SORRY the english is NOT my native to write you theoretic deep big text about electronics base. D6B is something hold-and-keep circiut keeping a level zero of D4 output on all 'working circle'. D9D is activated NOT AT THE END OF PULSE TX, but ON THE START OF THE WORKING CIRCLE - PLEASE LEARN THE PULSES' DIAGRAM I DID PUT THOUTHANDS TIMES.
  • g.s
    Can you explain Who is ROLE OF( D6B TL062) AND (D9D PIN 6.9,8..)
    why activated SWITCH D9D AT THE END OF THE PULSE TX ??
    SORRY FOR MY ENGLISH..
  • kt315
    revision of the schematic. in P-CAD 2006
    Delta_Pulse.rar
  • kt315
    yes, some people increases PPS to 300Hz and adds pot auto-manual. then they name it by SNIFFER XR-71 and gladly wildly
    told us that they have 'encreased the depth on cola can'. but there IS NOT MODIFICATIONS. THIS IS NOT THE MODS ABSOLIUTELY-!
    DP has to work GOOD WITHOUT THE POT and without PPS increasing. if you need in the pot something wrong in your board and find the problem.
