RELIC HAWK
  • o.mag
    hi mike
    I understand why you changed only the load side negative (positive being powered by the battery) but for tested the oscillator I changed both and the distortion appear on both sides. a higher current for IC does not really help anything
    The schemat of post 949 please me well. but I have problems for the simulation. I look for the mistakes I make
    olivier
  • bernte_one
    hello all here
    where can i find last pcb files of relic hawk?
    many thanks
  • Davor
    IMHO every oscillator that is running near saturation, supplied with well stabilised and low noise voltage supply will perform very well. The only difference comes from the oscillator design, and if it is symmetrical like push-pull - it will do very well.
    When you look at it, every amplitude stabilisation circuitry works the same way voltage stabilisation would do, and that's the whole point.
    You can always make a PI regulator that will push the oscillator transistor deeper into C class as amplitude rises. Its stability and noise will depend solely upon the power supply.
  • mikebg
    Distortion of negative half-wave (shown with green arrows). To avoid this, we should use center tapped TX coil and full wave rectifiers.
    I will show the analysis of this when I have time for our hobby.
    Here it is:
  • mikebg
    Hi Olivier,
    I analysed your idea in post #943 to use Vee rail for supply rest part of RX.
    For this purpose I increased 4 times current from Vee source (placing 500 ohm resistor instead 2k).
    To see collector curent of Q2, hold pressed Shift + click on collector lead.
    The attached image shows two drawbacks:
    1. Low efficiency of pumping pulse. We should decrease resistance of R1 until B=2A or conducting angle of Q2 decreases to 120 deg.
    2. Distortion of negative half-wave (shown with green arrows). To avoid this, we should use center tapped TX coil and full wave rectifiers.
  • o.mag
    hi mike
    Yes i can you open with CircuitMaker the compressed file attached in post # 941
    but I did not have time to fully understand
    olivier
    Hi Olivier,
    Can you open with CircuitMaker the compressed file attached in post # 941 ?
  • mikebg
    Hi Olivier,
  • o.mag
    hi mike
    OK : like this ! (the head is the red box )
    olivier
  • mikebg
    Originally posted by o.mag View Post
    hi mike
    a remark
    in this diagram the ground is connected to the - terminal of the battery.
    Ground use for the RX preamp.
    do you want creates a negative voltage supplied to the other OPA ?
    olivier
    No, Olivier.
    I think the TX has no enough power to supply increased looad because the negative rectified voltage is formed in half-wave when Q2 is not conducting.
    As I mentioned in post #937, my idea is to supply only U2 (the RX preamp placed inside search head).
  • o.mag
    hi mike
    a remark
    olivier
  • WM6
    I have no time to make it for simulation with LTspice.
    Mike
    It would be interesting to see filter characteristic of those rectifier.
  • mikebg
    Hi Olivier.
    I made TX circuit of post # 937 for SPICE analysis by you with CircuitMaker 2000. It is attached here in compressed format. I have no time to make it for simulation with LTspice.
    Mike
  • o.mag
    hello mikebg
    you right, you can cancel service Q3 (which I do not understand the utility)
    see post 929
    olivier
  • porkluvr
    Thank you. Whether right or wrong, your lectures are always fun and entertaining.
  • mikebg
    Mike, you should remove the components in the red box. Unless I am mistaken, the 68k resistor was put there to isolate an oscilloscope lead during setup. One end is a test point.
    The net segment that you labeled "Test" is connected to ground which means that 0V=test in your simulation.
    Right click the net, and then "Highlight Net" and you will see what I mean.
    Porkluvr, in my not humble opinion, you are mistaken
    Please click on emitter of Q1 to see voltage signal. The result is shown below. There is nothing interesting for measurement with oscope. Only a competent radio amateur will say that this is an inefficient TX circuit because the conducting angle of an amplifier class C is more than 180 deg.
    As a redesigner of this TX circuit, I would connect an oscope to output of U1 because for me, the P.I. controller is the most important thing in this circuit, so it should be tested. The P.I. controller should operate:
    a) quick (minimal settling time),
    b) with wide change of output voltage Vo (without saturation of U1) and
    c) stabile (without oscillation or ringing).
    When I connect R10 to ground for a test, amplitude of oscillation increases. The controller senses this and starts to increase output potential Vo of U1 in order to decrease amplitude of oscillation to previous level. The oscope will show this settling process.
    When I connect R10 to a positive voltage, amplitude of oscillation decreases. The controller should decrease output potential Vo of U1 in order to increase amplitude of oscillation and we will see on oscope if output saturates. To have very low voltage Vo without saturation, I use LM358 or LM324 instead TL074.
    However in practice, to test settling process, I will connect R10 to a pulse generator with very low frequency, for example 2Hz and will see with oscope if the settling process is enough quick and if the controller operates with ringing. SPICE also can simulate this.
