Surf PI Pro
  • sdesic
    I know that Surf pi pro can work with 9V battery - with less depth,
    can it work with more that 12V ?
    Looking to replace sealed lead acid battery 12V 1.3Ah with li-ion battery pack 4x3.6V.
    Is it too much ?
  • paku
    Hahaha yea i like that
    waste my time!!
  • Qiaozhi
    Originally posted by paku View Post
    throw it to trash
    That's one solution.
  • paku
    What was wrong with the board ?
    throw it to trash
  • 6666
  • paku
    thanks for the anwser i have fix the board
  • paku
    surf pi 1.2 long board from silver dog
    when i insert IC 4066 i get Hot On 78L05 is that have any one same problem like that
    i have Replace 4066 and Replace IRF9640 Still Same
  • Toros
    Yes, it works!
  • paku
    this version of surf pi pro is working or not
    SurfPIPro.zip
  • kt315
    Originally posted by sdesic View Post
    Can NE5532p replace NE5534p in surf pi pro ?
    Any modifications needed ?
    with remastering of PCB yes. take a part from HH revision that with two opamps.
  • sdesic
  • paku
    i have buy longboard surf pi 1.2 silverdog.co.uk
    i have finish assamble the board
    i get some problem when i turn on
    my ic 78L05 geting hot
  • chrspe
    Well, either the 12v battery pack was low or the GE Silicon II that I filled the clamshell with was still a little wet. After charging i just went out and threshold tone is back, depth is back. Cool.
  • chrspe
    My 6 inch coil was working great on the bench, waiting on scotch 24 shielding to come in. i was getting around 8 inches on quarter and 3 to 4 inches on 1/3 gram of gold. I could adjust threshold for just a small tone.
    After the shielding came I wound 2 layers of pe spiral wrap then the scotch 24 with no overlap. Now the threshold has no sound at all. Coil works but at about 1/2 the distance where it was.
    Does the shielding affect it that much? is there any tweeks I can make? My resistance stayed at 1ohm. Delay pot best depth at about 1/4 turn. Waiting on my inductance meter to come but coil calced out at 300uh.
  • sentella4d
    We'll I changed the coil to my 24 gauge,speaker wire,30 turn flat spiral coil and the distance increased to about 6 inches.But there is a problem,it will only detect metal if i touch both cables of the coil connection at the same time,otherwise it does not work.Also,I have a constant threshold tone,until I touch both coil connections,the threshold goes away,but it is the only way that it works.
