I don't know why is that resistor changed, I will use what ever is on paper... don't want any new changes...
This PI has already 4 different potentiometers, don't need more adjusting, I will use basic coil.
>So you think the resistor marked 12r is 150 ohms? I had that on my bom. I was going to use a 1 watt.
which one is this ?
On Apberg's board there's a resistor that appears to be a 1 watt.
Beware of the font glitch - symbol for ohm is often at the same place in a code map as a letter "w" so it just happens. In this particular case it is so because of the high voltage, and it makes sense. 1W that is.
Large cap 3900uF was 1000uF, for NE 5534 now LT1115.
Ok, thanks I missed that. So it appears now if you use NE5534 = 1000uf cap.
If you use LT1115 = 3900uf cap.
Yes, I see Apberg used a fixed resistor 3k3. But the etched board has place for trimmer. I was reading in the Surf PI (older version) where they used a trimmer and I have one allready. Has to do with adjusting the coil.
I've etched my board and installed ic sockets and jumpers. Some of the parts I have here allready.
I didn't start building yet, I am still collecting parts, so I looked at this schematics...
From that picture of assembled board ApBerg used fixed resistor 3k3
And C2 is 3900 uF at his photo... page 4 in this thread
Sdesic,
It looks like R2 can be either a 5k trimmer or 3.3k resistor. I elected to use a 5k trimmer. What are you using for C2? 1000uf?
For C8 I have 47nf instead of uf.
On Apberg's board there's a resistor that appears to be a 1 watt. Just above LT1115 (NE5534). It's also on the placement drawing marked "12R" ?
I am trying to make a list for Surf XX ...
parts are not matching PCB and schematics
C2 is 2200nF on PCB and 1000uF on schematics (+12 V and ground) ... bigger is better ?
R2 on PCB is 5k and schematics says 3.3k
There are few different models of Surf PI Pro...
SurfXX PCB and SurfPi Pro James Owen 2012 PCB ... are they the same device with only difference in PCB design ?
Have downloaded files titled SurfXX posted by Apberg. Found here http://www.geotech1.com/forums/showt...516#post149516 I Etched board but some of the components are questionable, to me. Could you kindly post a
partslist?
