The scheme is fundamentally correct. there may be some error in the values of some of the capacitors. I personally remove any parts of the scheme but I had no "C" meter to measure capacitors
Tesoro Tejon
Doesn't the Tejon contain a micro-controller?Originally posted by N@SKO View PostThe scheme is fundamentally correct. there may be some error in the values of some of the capacitors. I personally remove any parts of the scheme but I had no "C" meter to measure capacitors
If so, it's not shown in the schematic.
Yes, it does.Originally posted by Qiaozhi View PostDoesn't the Tejon contain a micro-controller?
IMHO, It's used to generate audio and maybe to control a 4053 chip ...
Original design don't have no 4024.Attached Files
Qiaozhi,
maybe on this board / thread ? http://www.md4u.ru/viewtopic.php?f=2...128364#p128364
I am not a member on md4u.ru
It's the Russian back-engineered schematics that I looked at. The Tejon has a micro-controller inside, and it looks like someone has replaced the micro with analog electronics.Originally posted by Firebox View PostQiaozhi,
Firebox, make anything simpler this is my suggestion to you. Tejon is based on u-chip, maybe PIC one. do you have access to HEX to program the PIC? not. CAN you write the code yourself? NOT. so why you need in the complicicated schematic??? there are massive of CLEAR analog VLF schematics you may begin from now!
PCB is wrong... Missing connections, and a few other connections are wrong !Originally posted by kt315 View Postyou may find PCB in RAR here http://www.md4u.ru/viewtopic.php?f=25&t=3056&start=250
vlaser makes...
Another problem, i can´t find a complet schematic with the PIC Controller
