TESORO GOLDEN SABRE
  • Virdi_248
    Correct the connections?
  • Virdi_248
    [quote = ciclonita; 111670] Hola @Virdi_248,
    ¿Dónde está su escudo Espaciado Gap?
    Extracto de la @artículo Ivconic de: TGSL Making.pdf bobina
    Un cordial saludo,
    Robert
    5mm a 10mm Gap (Escudo debe tener ABIERTO Gap)[/ Quote]
    Hello.
    Yes. Placed on my reel
  • dfbowers
    Originally posted by Cyclonite View Post
    Hi @Virdi_248,
    Where is your Shield Spacing Gap?
    Extract from @Ivconic's article: TGSL Coil Making.pdf
    Robert
    5mm to 10mm Gap (Shield must have OPEN Gap)
    It's there.. Just covered by tape.
  • dfbowers
    Originally posted by geminis74 View Post
    hi, Dfbowers
    I think you have the opposite RX input.
    RX START input is not inverted (pin 5 lf 353)
    END RX inverting input (pin 6 lf 353)
    if dual-tone sound, then turn 180 º RX
    greetings
    You are correct. Problem is solved by flipping over coil.
  • geminis74
    hi, Dfbowers
    greetings
  • Cyclonite
    Originally posted by Virdi_248 View Post
    dfbowers [quote =; 111643] ¿Tiene el escudo a tierra como se documenta? quote] [/
    wire connection of the arrow?
    It is just that, that is my question.
    Hi @Virdi_248,
    ... At the end leave 5mm to 1cm gap. This is OBLIGATORY! Without gap you get NO Faraday shield. Worth nothing! ...
    Robert
    OPEN Gap)
  • dfbowers
    Look at colors.. does this help at all? Bare GROUND wire in cable goes to same connection as GREEN wire on PCB.
    Does this help you at all?
    Good luck!
    Don
  • dfbowers
    Hi dfbowers and anyone else:
    What kind of wire do you use for connections to pots, switches, and even tx, rx coils? I see red insulated wires. Is it multi or single strand? What gauge do you like?
    Stuff I use seems to fight me...
    -SB
    Simon,
    I have been using 22 AWG (stranded) from Radio Shack. I think it comes in a few different colors.
    Don
  • Virdi_248
  • simonbaker
    Finally I put a shield. Problems, approached a finger to 1 mm of the coil or the wire and the detector makes false puffs.
    All is well connected.
    What's happening?
    magnetic personality, or nice sensitive detector!
  • simonbaker
    connection wires
    -SB
  • dfbowers
    What's happening?
    Do you have the shield grounded as documented?
  • Virdi_248
    What's happening?
  • Cyclonite
    In mineral-free soil.
    skip shield?
    Mineral Free Soil, can be Wet Soil, causing higher capacitance interference with the Search Coil. Trees, shrubs, and vegetation can, and will cause problems. HF interference may (will) influence your MD via the Search Coil. HF interference is today a far bigger problem than it was in the past.
    Why limit your search Coil to Ideal situations? What will you do when situations become less ideal? You will need two Coils, one with, and one without a Shield. If you want to go deeper, then why not build a larger Shielded Coil?
    You will be gaining nothing by leaving the shield off, and loosing all if the situation becomes anything less than ideal. Concentrating on a GOOD Shield, has all the benefits and advantages that you will not want to miss out on.
    Robert
  • Virdi_248
    skip shield?
