TESORO GOLDEN SABRE
Hi friends!!
I shielded the two coils and the wave is no longer deformed; And one more thing, the AC-GND-DC selector of channel 2 of my oscilloscope is failing, which is why it did not reach even the smallest of millivolts.
I put the coils back on the PCB with the shield to ground and got 20 degrees on RX. Here the image:
TX, higher amplitude wave at 5v, 20uS.
Pin7 of U101, smaller amplitude at 5mV, 20uS.
I am satisfied so far, thank you very much for your support.
Looks real good.Originally posted by Ruben2000 View PostHi friends!!
I am satisfied so far, thank you very much for your support.[ATTACH]57006[/ATTACH]
My PCB is not TGSL EDU, but it is similar. I used 2N2222A brand ST metallic type and the pin layouts are correct. You have to be careful with current transistors because many have changed the position of their pins, especially the Chinese ones; that's why better make sure by measuring the pins.
No, my friend, this is not the case, nothing changes, this is a universal contract for all electronic components !! Better to say, a big mistake for PCB Edu !!!Originally posted by Ruben2000 View PostMy PCB is not TGSL EDU, but it is similar. I used 2N2222A brand ST metallic type and the pin layouts are correct. You have to be careful with current transistors because many have changed the position of their pins, especially the Chinese ones; that's why better make sure by measuring the pins.
It's really embarrassing!!!!!!!!!!!!!!
Looking good.Originally posted by Ruben2000 View PostHi friends!!
You should have no problems. Your step by step approach is the way to go.
Many people assemble all components and then ask " the circuit does not work, what could be the problem?"
rubbish! the transistors he is talking about do indeed have different pinouts, there are at least three to my knowledge.Originally posted by mostafalesnar91 View PostNo, my friend, this is not the case, nothing changes, this is a universal contract for all electronic components !! Better to say, a big mistake for PCB Edu !!!
on 2n2222/a and similar testing the pins or having the correct manufacturers datasheet for the parts you have is really important.
Please do not use offensive words!!!!!!!Originally posted by sinclairuser View Postrubbish! the transistors he is talking about do indeed have different pinouts, there are at least three to my knowledge.
This is what you are saying, I have not experienced it yet !! I never trust the datasheet, I always check it before installing the emitter transistor and collector
