TESORO GOLDEN SABRE
  • Biogas
    Thank You!
    Tomorrow I buy some pots and capacitors...
  • eduardo1979
    Yes.
  • Biogas
    Originally posted by eduardo1979 View Post
    Works best with 100K with the 10K. Tested.
    The capacitors C14a,b,and C17a,b,are 10uF. It works better.
    Ok! Thank you!
    If I changed the C14a,b 22 uF, and C17a,b 22 uF capacitor for 10uF, and 100 k LIN pot for sens. then the TGSL works better?!
  • eduardo1979
  • Davor
    Yes.
  • silverdog
    Schematic has GB 100K, Sens 10K ?
  • Biogas
    TGSL_PCB_pot
    Pot. Sens. 100K. 10K NO.
    Hi Eduardo!
    Thank you, but on the PCB I see 10k!
    Then?
    And the ground extern pot? 100 k or 10 k?
  • eduardo1979
  • Biogas
    I have found: Sens 10k!
  • Biogas
    Pot
    Hello!
    The ground potentiometer is what value? 100 k Lin?
    The sens potentiometer is it the 100 k or is it the 10k?
    Thx
  • peterr88
    THX Silverdog, I try it!
  • Biogas
    Hi evrybody!
    The TGSL-EDU version have on/off swich or pot?
    If yes, wich is it?
    Thank you!
  • Biogas
    It is perfect, thank you!
  • silverdog
    of course not that pad is not connected - it was drawn to show where the existing pot is on the pcb
    I should have left the third wire off
  • HECTOR
    Like this ?
    [ATTACH]21397[/ATTACH]
    I don't think the third wire is needed on the CW side.
