The coil shieldings should not touch each other! You have to isolate the grafite spray coat with some isolation tape. The bad signal can be pre amp or maybe some of your channels is not working properly. How many volts do you have at pin 7 of LF353, the output voltage. It should be the ~45x of your residual balance voltage. Ex 4mv at receiver coil than output is ~180mV.
Bernte says it right.
