King Cobra PCB
  • all files in one archive http://www.avral.ru/0d4a9828e3b782a5e49e6f4da3c23375
    • about headset connector. there are two isolating beads on the connector - one inside and another outside of the panel. if you use a metal housing you have to remember about the solid isolation of the connector. points of soldering of the connector you can see at photos. this connector is mono,in original.
      regards.
ID:	334131Click image for larger version
ID:	334132Click image for larger version
            Hi, kt315! Unfortunately I was again not able to download files from your link. Rarely visit the forum and do not have time until the link is alive. Why she lives so short? Maybe you have another version of the placement of this information? I would be very grateful!
            • OKey danev! you are so rapturous and deliriously vigilant on my files... yes, this link is accessable only 1-10 day, no more, but it is without an adwertizing, banners and pay systems, ie absoliutely Free.
              I reuploaded http://depositfiles.com/files/qv8byvr46
              good luck
              • Just Downloaded the file within the last few days myself.
                I just re-compressed the file into a rar file. and uploaded to the Cloud, so if you want the file, download from this link
                • LOL, didn't see your posting that you relisted the download. Since I have room on my Cloud, I will leave it up.
                  • Originally posted by SVEN1 View Post
                    Dear Anatoly and Sven! It doesn't matter. I think that those files also will be useful to others. Thanks for your quick response and good luck!
                    Anatoly! This is not a special hunt for your files! Just you have the most complete and accurate information on this issue! Ačiū jums dar kartą
                    • It's a slow go working on the King Cobra since I am spending most of my time building my PI.
                      Just need to get the SMT parts for beneath the board and some IC's to finish up.
                      Thought I would show my efforts, so others building one would as well.
                      • Beautiful board work, inspiring.
                        • nice looking work, Sven... keeping the photos...
                          SMD components list attached.
                          best regards
                          smd_list.zipClick image for larger version
                          • I have access to 22uf 35volt SMD 7343H caps. I can use these for all the 7343h parts?
                            and 22 ohm 1206 resistors
                            • yes, certainly, because 35V more than enough.
                              best regards
                              • you can use 0805 type resistors (L=2mm) too. at a photo are 0805's setting on PCB.
