IGSL
  • bernte_one
    At first
    nice work ivconic and selim
    (i like the CE sign at the frontpanel - ready for european market)
    @jerry and wiltran
    you should try to fill the alu pipes with birds sand from supermarket or pet store then bending
    you can clamp the alu pipe among two trees or at the pipes from a fence gate that´s the cheapest way
    im waiting for the kit from silverdog
    hope my wife give me some time at night to solder
  • ivconic
    This one is even simpler:
    http://www.youtube.com/watch?v=PqZoE...eature=related
  • ivconic
    Tube bender, 2 documents:
    http://www.cnczone.com/forums/attach...4&d=1120529768
  • Jerry
    Originally posted by Alexismex View Post
    Hello jerry ,
    -did you test with the viper pipe
    http://www.thepipeviper.com/
    I did not, but the spring I used amounts to about the same thing. Thanks for that information.
    Jerry
  • simonbaker
    -6.2volt appropriate arrangement
    Nifty idea selim! Thanks.
    -SB
  • selim
  • Alexismex
    Hello jerry ,
    I think also is the type of aluminum....perhaps also with some heat ????
    thepipeviper.com Para aumentar suas chances de vitória em máquinas de slot, escolha aquelas que oferecem mais linhas de pagamento. Isso aumenta o número de combinações vencedoras possíveis durante o jogo.
  • Jerry
    Half an hour ago i talked to a friend over Gtalk on that subject.
    So he told me about steel spiral, used to bend Al pipes!
    Steel spiral is maybe 1mm less in diameter than Al pipe.
    Involve spiral into Al pipe and set it at exact spot.
    Than bend the pipe!
    Splendid!
    Al pipe should not break nor deform.... steel spiral is there to prevent that..
    I must try that!
    So simple...but so hard to recall such idea!
    I tried it with a steel spring inside and used a jig for forming and I got almost far enough and it cracked. I suspect I did not have the proper kind of aluminum. It was the right size but just something I had around here. Also have tried sand and got kinks that time, actually a couple times with each method.
    I envy the nice bends in the commercial stuff.
    One more thing, lots of people are sending their At Pro's in for new shafts with cam locks. They keep the old poles, so that may be a source of getting ready made poles.
    Jerry
  • Wiltran
    IGSL
    Thanks Jerry and Ivconic for the reply! Ive tried filling with sand, but if the sand is not contained the alum still splits. Inserting a steel spiral spring would probably work if it was a perfect fit. They used a steel spring to fit over brakes line to bend it. I could probably just buy the bent pipes somewhere, but I get a feelng of accomplishment if I do it myself.
  • ivconic
    Originally posted by Jerry View Post
    I have tried several times to bend aluminum tubing to make S-Rod for detector. No luck at all. I have tried several methods and just have not been able to do it without kinks or cracks. This would be an excellent subject for a thread if someone has the knowledge. It certainly isn't me.
    Jerry
    Than bend the pipe!
    Splendid!
    I must try that!
  • Jerry
    Originally posted by Wiltran View Post
    Ivconic, your MD looks professional! BTW do you bend your own aluminum pipe? I tried to bend alu. pipe with bad results!
    Jerry
  • ivconic
    Originally posted by der_fisherman View Post
    Does an aluminium shaft affect sensitivity in any way shape or form?
    Ask White's, Minelab, Fisher, Cscope, Garrett...
    Ask Carl!
    No...of course not. Shaft is made from Al pipe.. but lower segment is usually made from plastic.
    Maybe 30-50cm long it is.
    Should not affect nothing at that distance..
  • der_fisherman
    No i am not..
    Huge issue! Chronic issue!
    I manage to obtain shaft or two... from time to time..
  • der_fisherman
    Originally posted by selim View Post
    Beautiful, well done....thanks for the pics.
  • WM6
    Nice work Selim. Congratulation.
