Search Result
148 results in 0.0066 seconds.
Keywords
Members
Tags
so baracuda is motion detector only? (same like surf pi?) does anyone mod vco for bara? is possible to take the HH vco to implement in bara?...
Can you compare both pi and vlf detectors? Only people who used both for saltwater wet beach and underwater ? What isyour oppinion about xp deus in these circumstances compared to PI. Are u using only vco? I have a surf pi pro but never used in the beach because is forbiden in my country. It goes to...
"Static" is a mode, not a basis of operation. Technically the Garrett PP is VLF in that it runs at 12kHz, but it's not IB or PI. It's what I call a "loaded-loop oscillator" though I can't recall where I learned that term. Dave Johnson calls it something else, I can't recall that...
Has somebody made vco surf pi and can publish i Video? i cant imagine how it sounds .
It's a single sampling unipolar PI. VCO audio. It doesn't have earthfield compensation, no delay adjust or gain adjust. I'd imagine PICKINI to work equally well.
For an improvement Barracuda or Surf would be good options that aren't noticeably more complex.
Absolute value VCO
A small contribution, but it may help someone with ground balanced PI.
This VCO works for both positive and negative voltages, and assumes 0Hz at 0V. Its linearity depends on supply voltage symmetry, but as seen in the example here, it will work happily regardless, and 0Hz will always be at 0V....
include also Delta Pulse, Hammerhead PI
Delta Pulse - uses/advantages/disadvantages - nice to hunt with big coil, real deeper, power tuning to 450-500us pulse width max, ground cancel, true non-motion static mode, Geiger VCO sound.
Hammerhead - uses/advantages/disadvantages...
I do not blame you. A working circuit is a thing of beauty! I asked only because many people have shown favor for the more sine wave like audio that the original produces. Square wave are inherently nasty sounding becuase they have odd harmonics which are offensive to many ears. Triangle waves or sine...
I think your right about the fishing boxes and i would not trust them either...maybe just good as shower proof boxes...the eric foster type boxes look ok and very cheap price but i think i will go for the ultra box 206...im dissapointed that the ultra box will not take a surf pi pcb as too long for...
I believe that project is long dead.
He is attempting to identify ferrous and non-ferrous targets by examining the way the eddy currents decay. But, the decay curve depends on target conductivity. The GB control of White's TDI can be adjusted so that low-conductive targets give a high tone, and...
Many thx for this article! - I'll take a look at the Hammerhead, as I personally very much prefer the amplitude modulation (Whites style) threshold tone.
For what it's worth this (non-VCO AM) is the threshold tone method used on the most sensitive gold specific detectors - the Whites GM series...
while i was laid up recently the couple of raspi's i had were the only projects i had in the house, i built an emulation box to play my favourite retro games(raspi "B" 512), and a raspi "A" the smaller one i have been playing with an adafruit 3.5 screen and my modded barracuda pi,...
A PI detector will not do so well in an air test when compared to a VLF, but the main difference is when they are used in real soil conditions. The VLF will typically lose about 1/3rd of it's depth in the ground, and some detectors can lose as much as 50%. On the other hand, a PI will give about the...
Surf Pi Pro (Normal + VCO ?)
good day!
I need some technical expertise regarding surf pi ...
I found a scheme of the output part modifications with the NE555 VCO variant.
http://www.geotech1.com/forums/attac...5&d=1384056648
But I'd like to keep the original a scheme...
Looking for simple PIC or ARM to replace 555 VCO in PI detector
Hi All
I am working on a simple PI project and need to replace the typical pi 555 VCO with a simple PIC or ARM VCO.
I have searched for a long time and found and built this project , uses a 12f675, as you turn the pot the (square wave) frequency increases as the voltage increases....
as a person who's hearing is not standard, i can see a use for a pi depth meter, maybe you could use a vco to drive an analogue scale.
You can of course add an analog meter, but this will only show the amplitude of the received signal. Since the Surf-PI has a one-tone output for all targets, this might be beneficial as a depth indicator. For the PI detectors that have a VCO-style audio output, like the Minipulse Plus, there would be...
I haven't tested a Barracuda, but compared to a Surf-PI the depth is about the same. However, the Minipulse Pulse seems to be more stable, has a slow self-adjusting threshold (SAT), VCO audio, and a battery warning circuit. Whereas the Surf-PI has a single tone audio that changes in volume depending...
It is Beenthereuk schematic and I have tried to convert it to PCB in my post #29.
Not finished yet. As I understand N-mosfet have to be replaced with P-mosfet near speaker in that schematic with proper correction.
I see no more updates from Beenthereuk. I may try to finish it later. But...
Tepco replied to Uni-PI - Universal Pulse Induction Metal Detector board for microcontrollers like Ardiuno, PIC, AVR.in Tech ForumI mentioned this circuit for GB, sorry for hand written quality but this is still on prototyping board. I guess I have to explain lot about, but in short: This is simple analog solution, can be easily added to almost any classic detector, but with MCU controlled timing can be even better. Instead of...
It is very good idea to let sound works independent from detector frequency. But I think most benefits you will have from increasing of detector frequency. It will give you not only more sensitivity but also faster reaction on target so you can move coil faster without risk to skip some targets. 1-2...
With using interrupts it looks absolutely doable.
Also TPIMD - Tiny Pulse Induction Metal Detector has beed described on geotech forum: http://www.geotech1.com/forums/showthread.php?17507-My-New-Pi-Metal-Detector-(ATTiny-25)
It based on the same principles (timer - comparator - interrupts)...
thanks kt315 for that and the photos....i have already made the carl morland hammerhead detector but not tested the pcb as been so busy on the surf pi project...tell me on the hammerhead can i switch the audio vco/non vco using a toggle switch ????
I lost practically everything. The laptop and the external hard disk ceased to work. They stole the coils out of the boxes I shipped and destroyed whatever they could destroy. I am left with a box full of parts, all mixed up, since they emptied about half the sorting boxes into one big box.
