Hi simonbaker,
mineralized ground will increase the losses of the coil field. Of course, all consumers to the coil will decrease the coil Q. This is what is called: "Eddy current sensor!". One can measure the losses nearby the search coil because it is very sensitive. I don't...
Search Result
148 results in 0.0045 seconds.
Keywords
Members
Tags
Hi friends,
I have learned much last days. I was beeing confronted with some limitations of LTspice. Particularly, some parts are not available as SPICE models. Anyway, they would not also be available to other SPICE programs.
Sometimes, the solution matrix gets singular...
you have full non-motion if no feedback active (SAT), you have to tune frequency for a very low freq beating note... depending on your preferences... anything from 1Hz to 2-4-5Hz or more (threshold)... then nearing any metal the frequency will increase depending on size and distance. For far...
Hi Carl,
during the search for ultra low noise LNO, I explored that many high definition audio freaks also use such techniques. But most used by the RF engineers to get VCO and PLL most stable to meet the requirements.
Getting this technique to the PI pre-amp could bring...
Hi Eugene,
I think Atmel isn't a german company. Otherwise, I would boycott them in this case.
http://www.fundinguniverse.com/compa...y-History.html
But the main advantage of using Atmel µC is:
- damn cheap (ATtinys...
GBW (gain bandwidth product) and SR (slew rate) are related in op. amp. designs. When you talk of one... you indirectly talk of the other too.
The faster the op. amp. the more the advantages e.g. following the small decaying signal from the coil after 1st delay.
Noise is...
Schematics for Esteban...and other "skeptics"
Hi all,
cause someone here maybe think I've never realized an original schematic by my hands...
I post these two of my designs about PI detectors:
- 1st one is a simple PI that...
Coil, LNA & Ocilloscope
Whats the minimum signal level that a PI Rx coil wave form has(use approximately a coin and 12 inch distance). Can any one post screen shots of oscilloscopes,not simulation ones, the wave form with amplitude and time for this. Also use different metals from ur kitchen and check the wave forms across...
Hi Nelson,
nice to ear it works good, geb and disc OK. Really nice to see that people here appreciate this little and older tesoro's design like I do... that sometimes also an old design and an homemade detector could give lot of satisfaction.
Cool.
Nelson you're right on nugget hunting...
Hi ivconic,
I think too there is room for improvements on GSabre, expecially audio.
I was thinking at a simple audio power amplifier cause VCO gives me no e.g. disc informations like in other VLF, but just strenght of signal, like in PI detectors.
I think that CZ5's audio is...
Hi Reg,
Checked R28 thru R33, all values are correct.
TP9 voltage w/o coil both ends of threshold pot = +1.27V and -0.39V
IC8 pin 5 = 0V
TP9 increases with metal target (2-4 volts depending on target size). No target, the voltage jumps up and down...
VCO vs. Non-VCO??
I am new to this site and quite excited about building the HH PI unit. I keep seeing VCO? What does this stand for and what is most common, VCO or non-VCO. Yes I did a search and nothing come up on this.
Just need a quick simple explanation. Thanks.
Scott
Non-VCO PI schematic!
Hi strujas,
Would you please design a pcb for this schematic?
It looks be a good MD...!
Regards....
HI 1843,
I think could be good for beach/underwater hunting...but if you have no vco output...can't figure out what the signal strenght is.
I think could be an interesting "teaching" project too. But Delta Pulse or XR-71 or better GS4 could beat it in everything. The real...
my hammerhead PI
hello
i build a hammerhead PI from CARL design (non VCO option)With a PIC 18f452 for all the timing (freq TX,delay,sample...) a lcd module for timing control . I want to say that the hammerhead work very well . i have a coil 27 turn dia 20cm and i can detect 2euros at 25~30cm minimun in...
My First Results
My first resultas with PI tecnology
I used the IRF 640 for pulser, at 100Hz and 50uS of with, a 8.2 inch coils with 28 turns of 20 awg wire.
LM 709 conect as describe Sandbank and 4016P like swich to the integrator that is compose for a LM 741 idem to Sandbank Integrator....
BOM for hammerhead
been reading this forum for several weeks and I'm trying to decide on which pi to build..
I've looked over the schem's and placement pdf's.but I'm unable to find a list of parts for the HH..
I could read the schem's and make a list myself but i'm thinking that the errors/omissions I make...
Re: Hammerhead PCB - Carl DIFFERENCE Opt. 1 & 2
Carl ... Also, if it's not a bother, what is the difference between the "VCO" and "Non-VCO" versions, opt. 1 & 2? I am a little ignorant of the difference and PI machines...Thanks
John
Re: Congratulations!
Hi Fernando,
Congratulations!
It is the most complex, and probably the best Pi schematic, which I see so far. Of course, need time to analyze it.
Are you make some partial version on raster, or tested analog part with some kind of emulator?
My PILAB Project - Alfa Release
Hi All!
This is my PILAB project.
All this schematics are at "alfa relase" and
before I deciding to realize the 3 - PCB I'm posting to this forum and
wait YOUR OPINION and YOUR EXPERIENCE.
As you can see, this is an ibrid...
VCO or not VCO ??
Hi all,
I'm trying to find an answer on my question:
does it better to use VCO or not VCO for using detector like PI hammerhead?
As i 'm doing assembly of the CMS Hammerhead,i need to choose before make it: after it's will be difficult to change option!
I'll be happy to have...
Hammerhead update
PCBs were ordered today. I went ahead and got a 1-week turn-time. These are the thru-hole boards, not the SMT. I need to clean up the SMT layout, and will order them in about a week.
I still do not like the audio. The VCO design does not give me as much delta-f as I want. And the non-VCO...
VCO update
Thanks for the ideas below. I was trying to get the circuit to the left to work, but it was really flaky when driven off the PI final gain stage. This same circuit, flipped upside-down, worked great on my fluxgate mag project.
I think a big problem was the new noise...
PI boards have just arrived...
I just got the first batch of PC boards back, they turned out really nice. Single-sided, tinned copper, silkscreened, and drilled.
I'll try to dig up past emails of people who were interested in one, but to speed things up, please shoot me an email if you want one. I'm basically gonna cover...
Re: PI boards have just arrived...
>I'll try to dig up past emails of people who were interested in one, but to speed things up, please...
