DEEPER PI DETECTION DEPTH
    OK - I understand what you were doing now. Yes, now I can see they're the same.
    By the way, if you rotate the resistor by 180 degrees and replace it, the current plots can be overlaid with the correct polarity. Actually, the correct way to do this in SPICE is to use a zero-volt voltage source. Make sure you place it with the positive terminal on the left.
    It certainly looks like we've found the real source of the problem. Good job!
    I just plot -I(R6) to overlay them. But I like rotating the resistor better!
    I wondered what the best way was! I'll try to remember zero-volt voltage source next time. Thanks!
    -SB
      I cascoded the NMOS and the glitch remained, so I'm doubtful that it is CDG feedthrough. Interesting.
      If I lower the gate resistor from 100 to 10 ohms in the simulation, I get a similar result to your scope picture.
      • IQ Award
        Hi guys,
        ok, the glitch problem isn't a real problem. Let's leave it and focus to the interesting dark matter.
        The flat-top (t-on > TC) versus (almost) "linear" current ramp (t-on < TC).
        What is better and why?
        (Why dark matter? Well, that's a modern way to say "Damn it, I don't know!" )
        The winner of the IQ award will gain high respect and reputation. So don't hesitate to contribute. Good luck.
        Cheers,
        • BTW,
          I don't expect a good explanation and proof of the above IQ award. I just want to stimulate a good discussion and hopefully someone will find a good solution or a good idea. The discussion should lead to a better understanding of the matter and should generate new ideas as well.
          Feel free to talk about the above dark matter. Dark energy? Dark magnetics? Dark pulse? (Yeah, that's it!)
          BTW, I don't know the answer yet!
          (Do you feel better now?)
          But the question is really good. We should knock it out.
          PS: The question:
            PS: The question:
            I though we had already determined the answer to this particular question.
            Carl did some comparisons on a real circuit, and posted the results in #137 ->
            http://www.geotech1.com/forums/showp...&postcount=137
              That's right. For the same pulse width of 100µs in his example.
              What I intend to ask is, whether the almost "linear" region of the TX current ramp gives more benefits than the saturated region.
              This requires a new question of course.
                This in fact compares well with reality, except that the use of an ideal capacitor in series with the coil makes the glitches seem worse than they are in practice. In some simulations I ran, it was possible for the glitches to reach peaks of current as high as 60A.
                In conclusion, we just need to be careful when using the LTSpice inductor model, and to be aware that any current measurement you add to the plot pane [labelled I(L1), for example] does not represent the current flowing in a single component, but rather the overall equivalent network.
                Good work Qiaozhi. You've nailed down the main issue, zero ESR parasitic capacitance in the inductance model. Pretty sloppy work on LT's part.
                I'm not sure that Carls work has conclusively proved it. He's only tested two targets both of which may have had time constants too long to reach 'saturation'. Carl's experiment is actually consistent with longer TC targets in Tinkerers model so it could still hold true.
                  If we look at the power consumption, Sawtooth 2.4W x 17.3W Flattop, the answer looks easy. With even half the power consumption, the Sawtooth will give a much higher target response.
                  Then there is another advantage of the sawtooth, higher PPR, that allows for stacking or integration more samples, which gives a S/N advantage.
                  In short, Flattop is a waste of energy and time.
                  Tinkerer
                  • Originally posted by Midas View Post
                    The 2 samples that Carl used are fairly good representative targets. A Nickle with a very short TC and a silver dollar with a TC of more that 200us.
                    So, why do the simulations show different?
                    One of the reasons I could think of, is that the simulation uses an ideal "ring target". A coin is not an ideal target. The eddy currents are not uniform.
                    To verify the accuracy of the simulation, rings of short and long TC's would have to be used.
                    Is it worth wile?
                    Deeper understanding and better knowledge are always worth it.
                    When we are interested in target ID, like for de-mining or UXO, we want to thoroughly understand the reasons why a certain target responds differently from another target, be the difference in shape or metal alloy or caused by a different back ground matrix.
                    Morale of the story?
                    We need to design a simulation target model that can reproduce all the variations that real targets could present.
                    Big job.
                    Suggestions of how to design this universal simulation target model?
                    Tinkerer
                      Tinkerer
                      Hi Tinkerer,
                      that was the direction, I wanted the discussion to go.
                      (don't waste expensive battery power)
                      Putting the t-on time towards the "linear" region (t-on << TC) and increasing the pulses per second rate (PPS). Then "collecting" all the spectral energy of the response for the whole time (t-on + t-off periods).
                      Even the current does not achieve a significant level (compared to the longer t-on period), but it gives a higher dI/dt particularly during the on-time.
                      While doing this, low inductivity coils could be used with high PPS rates (6k - 12k or more). The high pulse frequency is far away from the low frequency noise sources as well (50/60 Hz mains hum).
                      Well, it's coming into the region of the VLF detector principles. Except, we have a wide band frequency response.
                        No, not a problem, but I like to know!
                        This is another "big coil vs small coil" comparison. Each has advantages. The linear ramp has more useful "on" time info. Flat-top has an advantage in magnetically viscous soil. Either one can be done in short TX times for high PPS rates. We're time domain here, we can do whatever we want. So why not do both?
                          How do you come to that conclusion? The parasitic cap parameters are there to be specified by you if you want to. It's your choice.
                          You just have to know when your are comparing apples to oranges. If one coil has the parasitic parameters specified, and the other coil does not and you instead include them externally, you can no longer just compare the "coil" currents and expect them to be equal, because one coil includes the parasitic components, and the other doesn't, right?
                          If instead you compare the two "network" currents, they match up nicely, showing LTSpice is working as expected.
                          Is there any mystery? Isn't that the way LTSpice should work?
                          -SB
                            Let's get a full simulation including the output of the preamp that agrees with the Carl's real tests showing 15% more output for the flat top charging pulse. I'd like to see what accounts for that extra 15%.
                            Up for it, Tinkerer?
                            -SB
                              How do you capitalize on that wide-band information? If you don't use it wisely, you are better off using narrow band techniques because you are picking up a lot more noise with wide-band, it would seem.
                              -SB
                                Big job.
                                Tinkerer
                                That would be so valuable; you on the money!
                                We first need some kind of data about real targets.
                                I would propose using our best, widest-band PI machine to actually bang away on a whole bunch of real targets.
                                Capture the responses with a good digital storage scope. Also capture the stimulating pulse.
                                Then we have to divine a general model for a target, and probably a linear dynamic system is our best start. We'll pick some arbitrary order like 5, and then try to estimate the system parameters from the response and stimulating signal using fancy shmancy optimal estimation theory.
                                Ooboy, that is a big job. Ok, let's just start by capturing some real data. Then we could at least tinker with target models heuristically and have something to match against.
                                -SB
