Eric and Brian: Upon further investigation I have determined it is not a stain left from the UXO red lable. I own two VALLONS and one has this same clean spot as yours. Does not match the size of the red UXO label though. Now I'm curious what it's from. Also never seen the red on the battery tube. I wonder if the soldier was issued his own detector and this was a way to identify his machine as it appears, at least in my instance, the fabric back pacs appeared not to be used. One of my detectors looked like it fell of a truck several times. I don't think the cases were used much.
Vallon VMH3CS Mine Detector
Hi Eric,Originally posted by Ferric Toes View PostHi Brian,
Yes, slacken off the 3 screws under the housing. On some I had to clean out compressed dust from the screw head. The screw at the coil shaft end should have a black plastic key in the gap which engages with a groove in the shaft to stop any relative rotation. I had a unit with this missing which caused the coil to be out of line. Worse still, one had the bottom of the key sheared off by that strong soldier. If the complete key is there then there is sometimes a bit of slack to stop it aligning properly.
What I do is to get a flat level surface and stand the detector on it with the coil at right angles to the shaft and pointing upwards. Put a spirit level across the top of the main case and adjust until level by rotating the body, with the screws just slightly slackened off. When the bubble shows that the box is level, tighten all screws.
Eric.
Excellent, thank you for the information, it is much appreciated.
The key at the coil end is in tact, so that's a good thing.
I will check to see how slack it is and then do the adjustment as you have described.
Think I will then give it a good clean.
Brian
Good info BrianOriginally posted by Mdtoday View PostJust to clarify...at high sensitivity settings, when I moved it in normal even height swing motion, the thing was stable. It chirped a bit when I was swinging faster and with a little more up and down motion.
Brian
In my experience of trying to increase the sensitivity, I just get increased false signals, which I think is related to ground mineralisation. Thinking about this now though, when I have increased sensitivity while detecting, I havent then re-ground balanced....I dont know if I should re-balance when I increase the sensitvity....Dont know enough about PI detectors to know if I should!
I will try this though!
Hi Carolina,Originally posted by Carolina View PostEric and Brian: Upon further investigation I have determined it is not a stain left from the UXO red lable. I own two VALLONS and one has this same clean spot as yours. Does not match the size of the red UXO label though. Now I'm curious what it's from. Also never seen the red on the battery tube. I wonder if the soldier was issued his own detector and this was a way to identify his machine as it appears, at least in my instance, the fabric back pacs appeared not to be used. One of my detectors looked like it fell of a truck several times. I don't think the cases were used much.
Interesting, I just thought the red tape might have been used to stop the arm cradle from slipping, so didn't think much more about it.
Its a May 2010 build and I also noticed a missing label from the opposite side of body from serial number is missing /removed.
Brian
Hi Kingswood,Originally posted by kingswood View PostGood info Brian
Yes, good point, I will try a few different things too and see where the happy medium is.
Intuitively, I would say yes but not knowing how the circuit/firmware takes care of its ground balancing it's probably best to just try it.
This is something Eric may be able to answer with his experience on the Vallon so far.
Brian
Brian: The red tape may very well be to stop the arm cuff from moving. The clean spot was definitely something applied across the body of the detector. Mine was exactly the size and shape of yours. Both my detectors are missing those tags on the body opposite from the date and serial # side. One detector is 7/2009 the other 7/ 2010. I have a friend who can tell me what the missing tags are. Will talk with him tomorrow. Sometimes when my detector gets chatty, I just use the quick compensation to calm it down.
Hi Carolina,Originally posted by Carolina View PostBrian: The red tape may very well be to stop the arm cuff from moving. The clean spot was definitely something applied across the body of the detector. Mine was exactly the size and shape of yours. Both my detectors are missing those tags on the body opposite from the date and serial # side. One detector is 7/2009 the other 7/ 2010. I have a friend who can tell me what the missing tags are. Will talk with him tomorrow. Sometimes when my detector gets chatty, I just use the quick compensation to calm it down.
Ok gotcha, yes I see the area you are talking about now, hopefully your friend can shed some light on this.
I think I will read the manual a bit more as I'm not even familiar with the quick compensation
Kingswood was asking about re-ground balancing after changing sensitivity so maybe this is the answer.
Brian
Yes I use the quick compensation at times too when the machine false signals for no apparent reason....Originally posted by Mdtoday View PostHi Carolina,
Brian
I do wonder if it does need to be ground balanced again when the sensitivity is changed....Hopefully Eric has an answer
Intuition tells me that if you make the thing more sensitive, then it would be more sensitive to ground noise also....so another GB may do the trick...
I fixed the twisted housing issue quite easily thanks to Eric's suggestion, looks much better.
Had the scope out for another project so thought I would take a peek at the serial data lines to see if they were active.
I didn't connect to RS232 port on my computer as it was getting late and I have no idea if the boot loader is active and didn't want to chance corrupting program memory.
However, A quick look at the TX line, at power up, it pulls up to roughly 5v then a few ms later pulses low then returns to 5v.
no other activity.
Ill setup with a terminal program and proper connections when I get time and try a few things out
Brian
RS232 Output.
Hello Brian,
I downloaded and installed the VEVA2000 program from Vallon. But on startup, it brings up a small warning box with the comment, " No valid Dongle found!. Application will be started in Demo-Mode!"
A look at this download directory : http://www.vallon.de/pdf/download/ shows several files available. An interesting but dated (last modified 2007) zipped file "Dongle Manual Install GUI.zip" contains amongst other things, a html doc "readme" that mentions a Hardlock key. This key, I assume to be the dongle mentioned at startup of the VEVA program. So, it looks like that avenue is closed. Pity, because according to the brochure for the program, it appeared to have a lot of useful things bundled together.
I would be interested if you do go further with your investigations. I don't have a FTDI usb dongle, only CP2102. I would not know where to start, to just get some basic logging facility running. Though page 36 of the Ver 1.14 manual might offer some small insight to get a handshake going.
Hi Greylourie,Originally posted by greylourie View Post
Thanks for the info, yes I downloaded the software, read the manual and came to same conclusion.
The data acquisition rate according to Vallon, is 40Hz but it is not clear if this is packets of information or single samples.
The data output could possibly be activated by a certain key sequence too but that is just a guess and of course the danger of doing this is that the boot-loader may then be activated and it's possible to brick the firmware if you are not careful, not good
I'm sure Vallon would have protected and locked things away to prevent misuse given the nature of the product but I'll dig around and see what info is freely available and not commercially sensitive.
I'll know a bit more once I hook up proper connections.
Maybe someone else has already tried this and would like to comment.
Either way, I'll post up the outcome
Brian
I had another quick look a the RS232 communications IO tonight and there is not much to report unfortunately.
The TX pin just cycles once on switch on as per attached pic.
After switch on, pin toggles to -5v for 340ms then pulses to +5v for 180ms and returns to -5v and stays there.
I did try a few different combinations of baud rates etc but no change.
Even tried holding down different push button and combinations on power up but still the same.
Ill try a few more options but without a protocol or sequence its going to be difficult.
It may be this particular unit, might be this series does not have RS232 enabled.
If someone else could try and have a look at the waveform, see if it matches then it would help narrow things down.
Brian
Brian: Talked with my man about the missing tag and turns out there was no tag in the first place. This is a Pre-designated area for a military IUID tag. The Brit's chose a different size and location for their tags. It is the small tag with the 2 D barcode beside the
VALLON date & serial number tag.
Hi Carolina,
Thanks for asking,at least we know now.
I'm going to turn my attention to the audio output as the sound is too harsh for me, screaming banshee noises aren't my thing
Thinking of doing one of Eric's headphone mods and adding a circuit to shift the audio frequency range down a little as I find it hard to hear the high pitch...a by product of years of guitar amps in my ears..
Brian
