Delta Pulse
  • Hi
    You can reach single layer PCB of delta pulse from this link:
    • Help me pls
      Dear Friends(Geo,Ivconic,Max,...)
      Thank u very much for ur helps on this forum.I made a DP,but I have some questions.pls
      guide me:
      1-For square coils(40*40,60*60 and 100*100cm),what is exact number of round and wire
      diameter for each one?(I am searching for medium size objects over 4 ft depth)and must
      coils had sheild and enamel?
      2-How can i connect microAmper meter and headphone to DP togather?
      can i connect to SPK point?
      thanks again and goodluck
      • Originally posted by Batman View Post
        guide me:
        1. all about inductance you need, your damping resistor and things like that: cause coil are large you need fewer turns than with e.g. 8'' round; you can use a coil calculator or hand made calculations or just experiment with less turns of than with smaller coils
        Example: suppose you need a 300uH coil... and 1m*1m shape... 1m^2 is what you get from an e.g. round coil of 55cm diameter... so you can use inductance formula for round air core coil to get turns:
        I've made and result for 0.3mm diameter wire is 16 turns for 300uH for 1m*1m... but then you have always make tests by your own to be sure coil is ok for your setup (e.g. using scope to see how good is damped etc etc)
        You have also to consider resistance about the maximum current required at each TX pulse... and limit if needed by a small value resistor of few ohms 2W.
        About shielding ... if you use larger coils you can suspend them far away soil e.g. 20cm and more... so you can also omit shield cause soil influence will be low at that distances.
        About enamel depends if you use enamelled wire or plastic pvc covered wire... that you can use in larger coils... in any case each turn need to be insulated from the others.
        2. uhm... well you can take a look at XR-71 about meter... XR-71 and DeltaPulse share most of the circuit... that's about the same so you can mod tailoring stuff for your needs; for headphone you can connect a socket to speaker wires and use a resistor to match better inductance of headphones (sometimes for hi-quality HP the inductance is around 150ohm... for common stuff you can use a 27-33ohm resistor there... that will give you a good volume without overload "normal" HP speakers).
        Kind regards,
        • Hi. Delta Pulse (100Hz) need a 1mH coil, so for any dimension you need make the right calculate. If you will make a 1x1m coil then it is better to use at least 1mm dianeter wire. At 60x60 0.5mm wire will be OK.
          Don't forget to play with dumper resistor.
          • Thanks
            Dear Max and Geo
            Thanks for ur guide.i will try it.
            goodluck
            • MDEFIED DELTA
              my modefied delta pulse metal detector schematic fm this site can detect coke can at 5ft or geater.
              • Originally posted by ram View Post
                Where is it? Send the schematic please.
                Regards!
                • User Manual
                  Dear Geo
                  thanks for ur Guide again.where can i fine user manual for DP ?
                  • What is the size of your coke can ?
                    Fred.
                    • It was 200l Coke (oil) barrell!
                      • Originally posted by batman1972 View Post
                        Dear Geo
                        Hi. Try to find the file "Bandito-pulse-eng". It is a detector exactly the same with DeltaPulse
                          Bravo. Maybe at your country you have coke-cans bigger than 330ml.
                          • Hi,
                            5ft for a coke can ? In air ? What's size of coil ?
                            Maybe a big coil can detect (in air) at 5ft... but not in the ground... in the ground is another story for these super-air-detectors
                            Me can detect 1eur coin at 50cm, in air, with a "doped" PI and 8''coil... but that's another story !
                            On soil the same PI works nothing!
                            Kind regards,
                            • User Manual
                              Geo My Friend
                              Do u mean BANDIDO detector of Tesoro ?If yes what model exactly ?
                              thanks and goodluck
                              • User Manual
                                Dear Geo
                                Do u mean BANDIDO of Tesoro ? If yes what model exactly ?
                                If possible for u,Inset Link for DP user Manual Download.
                                thank for ur help and good luck
