Originally posted by jap
Delta Pulse
Thank you Jap but the link no longer works http://rapidshare.com/files/78012726/layout50.rar.html.
Hi Nikolov
Where you applied the coil specification true,the difference here cable production difference(quality of cable)
its,,,,OK.
best time
j.
As I can not open the file .. lay,
Hi Freddy67
all u need in link http://www.sonsivri.to/forum/index.php?topic=8502.0
best time
j.
Hi Nikolov
good test,if Freq is 130Hz on NE556 pin9 its good for deep(DP is deeper).let all in place
--Try CAN Cola Iron And see the difference.
best time
j.
OK, I finished the 32cm coil, 1L alu can detect on 65cm
. Resistance is 5.4R. With this resistance what to change R5 or R6 or.....
BUT I found some "mistakes" on board. In my board PR is 250K instead 200K and for 250K PR -R1 will be 680K or 470K
Hi Jap
It depends if the circuit is irradiated, if we use the method of iron or if you draw by hand. It is better to have the two versions.
Hi Freddy67
THE First will be used directly for printing and does not need to be reversed
This importance,,,,
best time
j.
Hi pigeon
a schematic that U need it .
best time
j.
