Delta Pulse
  • Hi Nikolov
    The 2 coil 1x1m square , 32cm are same L...mh
    best time
    j.
    • yes they are same, what round coil is your advise for delta pulse 28cm maybe?? or.....
      1x1 is huge for operating I want something small
      tnx
      • Hi Nikolov
        use Coil Calculator by Qiaozhi its good tool.
        -small coil for small ,start 23cm coil.
        best time
        j.
        • Originally posted by freedan3d View Post
          no szucs_g. p6 and p7 that i show on pcb and schematic use for lcd
          I attached some file for that lcd.I have delta pulse dircriminator lcd circuit too .i can upload here if you want
          freedan3d
          Hi all
          It is possible to use the original lcd discrimination for delta pulse klasik if so can you give me location of p1/p2/p3/p4/p5/and p9
          Thank you very much
            sz, can you draw these points A...E on the schematic? tia
            hi
            please where's the emplacement for r50and r51 in the pcb
            thank you best regards
            p.
            • Hi pigeon
              a schematic that U need it .
              best time
              j.
              • Originally posted by pigeon View Post
                hi
                p.
                hello, its are absent at the Turkish PCB.
                yours
                • Hello to all
                  What are the two straps? According to the diagram, they are connected to the + and - E. Is this correct?
                  All photos there is no visible connection.
                  With my thanks and greetings.Click image for larger version
                  • Hi Freddy67
                    Yes,,,two are OK
                    best time
                    j.Click image for larger version
                    • Hi and thank you very much Jap.
                      It was to be sure.
                      Enclosed the circuit Jpg. As I can not open the file .. lay, I am amused to remove all the components and redraw the circuit in black with Paint .
Name:	Delta Pulse.JPG
                      And reverse
Name:	Delta PulseReverse.JPG
                        yours
                        thank you
                        best time
                        • Originally posted by jap View Post
                          Hi pigeon
                          best time
                          j.
                          thank you
                          best time
                          • Hi Freddy67
                            THE First will be used directly for printing and does not need to be reversed
                            This importance,,,,
                            best time
                            j.
                            • Hi Jap
                              It depends if the circuit is irradiated, if we use the method of iron or if you draw by hand. It is better to have the two versions.
                              • OK, I finished the 32cm coil, 1L alu can detect on 65cm . Resistance is 5.4R. With this resistance what to change R5 or R6 or.....
                                BUT I found some "mistakes" on board. In my board PR is 250K instead 200K and for 250K PR -R1 will be 680K or 470K
                                Freq is 130Hz on NE556 pin9
