Considering last images (Tr3min280uHcoil.png and Tr3max280uHcoil.png), and given ranges 100-700us, values are:
R4 3.91k (measured)
C3 22n (I can't measure capacitors, so I give printed value)
DEPTH 25k
Also, I see on your schematic STTH1210D diode, can I use MBR1035 instead?
Schottky is not able work in circuits where more than 50V. guys, learn the blsht electronics, more books around you are able get in global net.
do not ask me primitive questions. here is forum for metal detectors, not for absolute beginners.
you need be looking for more than 1000-1200v diode.
OK, I had no idea that there would be more than 50V in this circuit! Thanks!
Also, I have bought another oscilloscope probe, so there are measurements for Tr3 and Tr4. When I compare signals on those points, I have 30us minimal and 130us maximal delay between imuplses, depending on Delay (or Sensitivity) potentiometer position. Are those values OK, or I need to adjust something?
DELTA PULSE is "delta" pulse! P-P amlitude of delta pulse is getting 1000-1200 Volts on maximum PULSE WIDTH 500us!
why do you not want to grasp what is the delta pulse???
I have some knowledge on electronics, I have built lot's of audio stuff, but this is my first detector. Excuse my ignorance, I am still learning and want to learn a lot
I am trying to figure out which components I can change, since it is not possible to buy some "exotic" stuff like that diode here where I live. According to what you say, I believe that DSEI12-12A could be the replacement, since that is the most similar diode I can find here (1200V / 11A / 50ms). And if switching speed and power are not critical, I could use RGP30M (1000V / 3A / 500ms).
However, thank you very much on your help, your knowledge is great and everyone can lear a lot from you! I'll be very grateful if you can comment my oscilloscope measurements.
Dear KT351, I live in Serbia, not UK. The price is not the problem, it simply can not be found here, and I am searching for alternative. Thanks for understanding.
ok! i have Maxymus in skype. if you want something from your place ask him, i will give you his account.
also you may rely on ivconic - Ivitsa as he is a super-active geo techers. overload his message box by requests,
he will be happy!
OK, I've messaged ivconic. Thanks! But you could also answer about maximum current through diode? Is 11A enough?
Here's where you can see the catalog features everything you want. http://www.alldatasheet.com/
I tried STTH1210 but honestly coil 20cm decreased sensitivity to small objects, so try with or without diode and see the difference.
Read this :
