Pa jel imas cime da se hvalis ?
Delta Pulse
thats true. for big PULSE WIDTH maybe it has a value, but for low one not. people are so idiotically conservative,Originally posted by gaby_sult View PostHere's where you can see the catalog features everything you want. http://www.alldatasheet.com/
I tried STTH1210 but honestly coil 20cm decreased sensitivity to small objects, so try with or without diode and see the difference.
Read this :
http://www.geotech1.com/forums/showt...704#post225704
that instead to try find a mosfet with 1200v they are wasting a time on finding of the diode.
all only ask what diode is best.
At which point you measure this? I tried at pin 6 of LF357, but I have nothing similar there? I have a Surf PI and I successfully measured this at output of NE5534, and then set damping resistor, but I am not sure where is this point on Delta Pulse? Could you please help?Originally posted by kt315 View Postdamping resistor is like a tuning matter. look at this illustration.
[ATTACH]24418[/ATTACH]
OK, I found that I shall measure it at TP3, it was in this post: http://www.geotech1.com/forums/showt...9943#post89943.
Also, I found out that my IRF740 was not working, so when I replaced it, everything runs!
Is 11A enough?
And perhaps I don't need it at all, since we plan to use only small coil (this is a gift for my kids).
