SBG- slow motion metal detector
No, I can't because I don't have any.
Unlike the vast majority of my colleagues, I write component values directly on the pcb and do not create a separate "BOM" (Bill Of Material) list.
Just in case I plan to have JLPCB make my pcb and solder the components; I am forced to do it, and it is a rare case.
In this case, from the beginning I planned to make only one device and solder all the components myself.
That's why I didn't make a BOM list.
Ok, I know, it's bad practice and it's not professional.
Ok, that's me.
That's why I published here (UP, post #106) a large and clear picture of the components and their values.
It is very easy to work with.
I assume you don't have a Sprint Layout? Or do you have?
If you don't have; be sure to download and install, version 5 or version 6, it doesn't matter.
You will find the installation easily on the Internet.
Then with that software you can open this file and everything will be much easier for you:
When you analyze such schematics; some things are self-explanatory, they don't have to be literally connected on the schematic.
"Virtualg Ground generator" is a separate stage (logical) and shows how the virtual ground is generated.
It is understood that the output is connected to all points on the schematic that should go to virtual ground.
There are all in all only the two basic ways of drawing a schematic; "literal" and "academic".
The "academic" style is easier to follow and requires a full understanding of the schematic, but is much cleaner and clearer.
"Literally" connecting is easier for someone who does not understand the schematic (or he wants all to be literally connected), but it is much more difficult to follow and observe the circuits.
Both ways are equally correct and it is a matter of personal preference of the one who is used to it.
Sasho is someone who certainly cannot be considered to not understand schematics well, because he is the original author,
it is certain that he understands his work best, better than all of us.
But Sasho has his own style in drawing schematics and for him it is the best method. I respect that. "Old school" I would say.
I am a member of that other "school" of drawing, the "academic" one, which does not literally connect everything on the schematic,
but tries to separate and break down the schematic into logical stages.
There is nothing wrong with either approach.
Write in English son, or they'll give you a warning.
<Здравейте!
Аз съм ученик в 12-ти клас в техникум по електроника.
Забелязахме несъответствия между платката и принципната схема,особено в генераторната част.Там двата кондензатора в базите трябва да се съединят на късо,иначе режимът на транзисторите няма да позволи генерация.
Не сме проверявали подробно платката,в това отношение ви се доверяваме.
Някои анотации върху пратената от мен снимка на схемата
са подробности-за да установим потенциометри,ключове и други,които ще се изнесат на предния панел.
Мого ви благодаря за интереса!
Всичко най-хубаво!
След като конструирам уреда, ще Ви пратя отзив>
Is equal to
Hello!
I am a 12th grade student at a technical school in electronics.
I noticed inaccuracy between the board and the schematic diagram, especially in the generator part. The two capacitors in the transistor bases must be shorted, otherwise the transistors will not go in generation.
I have not checked the board in detail.
Some annotations on the picture of the diagram I sent ,are details - to identify potentiometers, switches and others that will be placed on the front panel.
Thank you very much!
All the best!
After I construct the device, I will send a review in the forum.
