Whites Surf PI schematic
  • nelson
    Hi, yes i agree with Dirceu.
    My detector is working ok, but need just more deep. I think is a problem with somo wrong component place on the board.
    Nelson
    Originally posted by humhum View Post
    Hi DIRCEU and NELSON , How is the result of metal discrimination in your machine?.
  • DIRCEU
    Hi! HUMHUM
    Really discrimination do not exist but it is a good machine for beach hunting.
    I am working now in BARRACUDA.
    Best Regards
    DIRCEU
  • humhum
    Discrimination
  • nelson
    Thanks Dirceu. I will try later this mod. Anyway i think i must check al components values, cause my detector can realy get more deep. So may be some capacitor or resistor in the circuit is diferent and this causes my poor sensitivity.
    Nelson
    Originally posted by DIRCEU View Post
    Hi! NELSON
    Does 15 us delay.
    DIRCEU
  • DIRCEU
    What does C9?
    Nelson
    Hi! NELSON
    Does 15 us delay.
    DIRCEU
  • nelson
    What does C9?
    Nelson
    Hi! NELSON
    Do You adjust the off-set trimer?
    I change my magnetic earphone by one piezo and 220pF capacitor instead 1 kpF (C9 in original schematic).
    All distances of targets related for me refers at final audio detection (only a small "click").
    Dirceu.
  • DIRCEU
    Hi Dirceu, i just made the coil you did, and star to play with trimmer has a dumpping resistor, selecting values from 280 to 450 ohms and the detector works good btw 310 and 400. Sencitivity noted smal increments,but never has you got. Best performance was 360 ohms, a 1.8 cms compper coin was detected at 22 cms, this on my lab, i don´t know if results may be beather wint the unit assembled and on the field.
    By the way i ll make another surfmaster to see if i can get beather on it.
    Nelson
    Hi! NELSON
    Dirceu.
  • nelson
    Nelson
    Hi! NELSON
    Yes! the definitive value for dumping resistor is 370 Ohms (for me).
    Put a trimmer instead of resistor and adjust for obtain max distance from target.
    DIRCEU
  • Gyur666
    In my experiences there are some interaction among coil parameters, cable, capacitor (1000uF) and dumping resistor. For example I tried 4000uF and gave a bad result. Maybe need to change the offset. It’s very difficult.
  • nelson
    Ok, so just a small diference from 390 ohms to 370 ohms, correct the sensitivity.
    Is good to know that. I will experiment with a trimmer, take the best resistance value and then replace with correct resistor.
    later i will let you know my results.
    Thanks a lot and have a nice day.
    Kind regards
    Nelson
    Hi! NELSON
    DIRCEU
  • DIRCEU
    Today i finish my radial coil. This is 185.8 uH and 1.2 ohms. Just tested on my lab and results are not to good jet. Tell me did you change the dumping resistor value?
    Nelson
    PD the coil is 19 cms, 22 turns
    Hi! NELSON
    DIRCEU
  • nelson
    Nelson
    Hi! NELSON
    How is your work with SURFMASTER???
    DIRCEU
  • DIRCEU
    Hi! NELSON
    DIRCEU
  • nelson
    Yes Dirceu, i has just send you an email.
    Many thanks
    Nelson
    Hi! NELSON
    Do you received my E-mail???
    DIRCEU
  • DIRCEU
    Hi my friend i had just reply your private massage.
    But i can give another email too, this is [email protected]
    And my main email is [email protected]
    Nelson
    Hi! NELSON
    DIRCEU
