Hi All, I'm sorry for responding so late.
KingJL,
Please below is answer to you question:
Parts used for circuit:
-Diodes: SBYV28-200
-Mosfet: BUK455-600, IRF710, BS170,
-IC: TL271CP, CD4093BE, DC40106BE, LM393N or LM393P
- chemical 100uF capacitor/250V
-The Remove test of Diode between TX and 100uF/200V: condition is the files names
-100uF/200V polarity:
(-)Pin connected to –VB, (+) Pin connected to Diode SBYV28-200& 68ohm & 110K resistors.
When no diode:
(-) Pin=-6.8V
(+) Pin=-6.8V
When diode set:
(-) Pin=-6.8V
(+) Pin=-1.14V
Mick,
-I will tray to find Litz wires for the construction of better coil,
Can I use the type of wire that I've ( for new coil respecting the caracteristics)?
For the curent I've measured with scope using shunt method ( measuring volt wave @ resistance=1ohm in serie with the coil)
*Please let me know if this is the right way to measure it's curent?
-Ch2 was taken from one lead of the coil. As mentioned in these attachements
-For IRF710, tab is isolated from the board.
note:
*TLC271 circuit is a little bit of heat
Rgds
J.Anis
KingJL,
-Diodes: SBYV28-200
When no diode:
(-) Pin=-6.8V
(+) Pin=-6.8V
When diode set:
(-) Pin=-6.8V
(+) Pin=-1.14V
Mick,
note:
Rgds
J.Anis
