RELIC HAWK
  • RELIC HAWK
    I Put the parts list in a note-pad . So its easy to move around, also easy to correct...........Eugene
    • Hi,
      I've made some mods... added -2.5 and +2.5 rails + connections.
      Changed some pads to bigger ones and checked a bit...
      I think there could be some other mistake... so better check well first.
      Kind regards,
      Max
        Kind regards,
        Max
        Hi Max,
        thanks,
        I have been improving my version too,most are small details, did you make big changes or found importnant mistakes so i can correct them too ?
        So we don´t end with two very differents PCB
        regards,
        Fred.
          Hi Max,
          thanks,
          regards,
          Fred.
          Hi Fred,
          not big mistakes just that at U12 and trimpots you made no connections to -2.5 and +2.5 or pads but I've used your layout, my idea is always we all use same pcb at the end... so why don't use last version and just mod it more ?
          I've made that changes but would be really good if you will check pcb layout and spot if I missed something along the way...
          Kind regards,
          Max
            Hi Fred,
            Kind regards,
            Max
            Ok yes Max,
            yesterday night i made a lot of small corrections , nothing important but rounded corners etc. ,i will post it here soon with your mods.
            thanks,
            see you,
            Fred.
            • Hi my friend.
              Could you please send me a copy to [email protected] or to [email protected]
              In advance many thanks
              Nelson
              Originally posted by amtech2005 View Post
              Nakky , Sprint 5.0 open's Relic Hawk perfect. If you need a copy of sprint 5.0 , I can e-mail to you...................Take care................Eugene
              • Last version with merged mods from Max.
                I used i slightly diferent path.
                From now on i will only mod the last posted layout,so we dont have 2 diferent versions.Also a list of mods made would be usefull each time.
                Here beside small details, i used a jumper to "B" connection and changed value of resistor from U12/12 to 27K instead of 22k .
                regards,
                Fred.
                  regards,
                  Fred.
                  Hi Fred,
                  you already made some corrections, good. I think the best way to help you now is signaling where are problems in pcb so I'll do by pictures and just you will make modifications using sprint layout.
                  This way we'll end up with a unique pcb design.
                  Here's the first I spotted already: I think we need that yellow track there.
                  Kind regards,
                  Max
                  • PS: we need also this -2.5 point connected to -2.5 rail and an extra pad for C.A. at +
                    Kind regards,
                    Max
                    • Hi Max,
                      Excellent!
                      sorry i didn´t notice your mods to the supply and pot, no problem.
                      Yes it probably the best way to avoid confusion,i will do this tonight.
                      Hope we are close to the final version ...
                      I can find all the IC´s including the NE5534 but not the TS27mX
                      Regards!,
                      Fred.
                        Hi Max,
                        Excellent!
                        Regards!,
                        Fred.
                        you could use TL072, TL074 for tests , better if something LS204, LS404 as alternative to TS27Mx.
                        Kind regards,
                        Max
                        • Fred and Max..........
                          Very good work
                          Congratulation
                          Thank you
                          • All Ok ,thanks for IC´s info.
                            regards,
                            Fred.
                            • RELIC HAWK
                              Fred And Max , Great Work on both the Schematic and the Printed Circuit Board !!!! My copy of Sprint layout only opened the file and I could not print ,and it was in German. So I am trying different Gerber viewers . This .Lay-File must be the newest Sprint Version. If I find another option I will let everyone know. Maybe it would be nice to have alternative formats , since everyone has their preference on PCB software and or Vendor. But so far , the work on this Project has been "fantastic". Thank-You Again.....Eugene
                              • Originally posted by amtech2005 View Post
                                Look at schematics-pcb freeware shareware, layout 50 crack.
                                Thanks to karlos x!
                                Regards!
