Minelab 8000
  • Hi all,
    I have finally added an 18 inch DD-IB coil to the coil comparison.
    It is not good performing. The TX/RX coils are relative small compared to other coils. This is the reason for.
    The zipped Excel-file of the comparison data is attached.
ID:	447638 Click image for larger version
ID:	447639 Click image for larger version
ID:	447640 Click image for larger version
    • Hi all,
      the Super-D coil comparison (GPZ 7000 coil) would cause me much more work. I have to sweep the target over a large surface area instead of sweeping it at it's maximum response axis line.
      At each target height, I have to take the maximum value target response. So I will have a large two dimensional target response table.
      Designing the coil won't be an issue anymore however. But putting the target response is a big deal.
      Will it be really worth all the work?
      • Regarding the Super-D coil:
        I don't know any internals how the two RX coils being processed, connected, nor their inductances.
        Is this a two-channel processing or are the RX coils connected as anti-interference coil.
        As long as I don't know the real answers to the questions, I can not make the coil analysis.
          They are combined as anti-interference coils. That's why you can't simply bob the coil to GB, you need that yellow toroid ferrite they include.
            Hi Carl,
            thank you for the info.
            As I have assumed, the coil analysis will cause a lot of work. The Super-D coil configuration wouldn't do well too. So there must be gain compensation in the front-end amplifiers to get the required sensitivity.
            Cheers
            • Hi all,
              I am implementing the 3d cubic spline interpolation. I hope, Google AI didn't make any bugs.
              This feature will help reduce the number of scanning points and make a smooth coil geometry and more accurate coil designs possible.
              So the evolution and development goes on...
