My PCB is not TGSL EDU, but it is similar. I used 2N2222A brand ST metallic type and the pin layouts are correct. You have to be careful with current transistors because many have changed the position of their pins, especially the Chinese ones; that's why better make sure by measuring the pins.
No, my friend, this is not the case, nothing changes, this is a universal contract for all electronic components !! Better to say, a big mistake for PCB Edu !!!
It's really embarrassing!!!!!!!!!!!!!!
Hi friends!!
I shielded the two coils and the wave is no longer deformed; And one more thing, the AC-GND-DC selector of channel 2 of my oscilloscope is failing, which is why it did not reach even the smallest of millivolts.
I put the coils back on the PCB with the shield to ground and got 20 degrees on RX. Here the image:
TX, higher amplitude wave at 5v, 20uS.
Pin7 of U101, smaller amplitude at 5mV, 20uS.
I am satisfied so far, thank you very much for your support.[ATTACH]57006[/ATTACH]
Hi friends!!
Hi friends!!!
I am in the RX stage, I placed a 15nf capacitor in C6 (measured 14.99nf) according to the calculation I made to be able to obtain 16.12KHz (non-resonant) with an Rx inductance of 6500uH. I put it on the oscilloscope and I want to know your opinion about it, here I put the image: It is at 20uS, 5V (higher is TX).
20uS, 0.1V (bottom pin7 U101a).
The charge pump circuit used to create the negative Voltage is not regulated and dependent on components and loading.
Anywhere between -5V to -8V will work to power the op-amps.
hello banner!!
This time I placed all the components of block number 4, also placing the IC U107 (LM35; now being loaded I took the measured at the point of -5V and got -6.35V.
