TGSL EDU with 27 cm DD coil works good but it has some rusty iron problems.
It finds old rusty iron and it beeps regularly in disc mode (set to disc out most of iron)
when I dig it up then it is not audible target... is there any solution for this ?
Pinpointing with big coil is also problem.
Sometimes I think all metal pinpoint is in one place and disc in other ... difference of 20-30 cm sometimes.
All metal is too sensitive to small peaces of iron ... can be corrected by lowering sensitivity (and loosing some depth)
Started building concentric coil but I am stuck at winding busking coil over...
Used 0.2 mm enameled wire so I had to change no. of laps.... and need info on measurements TX and RX are as should be 6.5 and 6.0mH.
Bucking coil is x mH ?
now i build success TGSL Its Very Good
.... in air test i got 27cm on 50cent silver us dollar but when i buried at about 10cm in soil i no longer detect it.
