@NĂ¡ndor :
Do you have the coil connected ?
If not, the oscillator won't run and you can burn the transistors in the negative voltage generator.
many thanks for the quick answer,you are right it was my fault
,but when i measure voltages in IC pins i get +7.8-8 on pin 4 and -2.2 on pin 8. I think that negative voltage is not enough right?
i will recheck every thing that should help me.
.What could be the problem?
