TESORO GOLDEN SABRE
  • There is! And very big! This device works in dynamic mode, not static. He needs energetic motion over the sensor, not *sloth waving*...
    • Originally posted by ArchibaldSTM View Post
      Ok, you are right, I should to move the coin very fast, but do you think it is possible to move the loop faster than this when searching on the ground or not ??
      • Originally posted by mostafalesnar91 View Post
        Typical coil sweep speed is about 1 meter per second.
        • very weak results for my device with small loop(5.5 inch)
          No separation! weak disk mode !!
          Frequency TX 14.23
          • Hello friends, do not be tired.
            I want to make a 30 cm coil for TGSL.
            Can you help me?
            Thank you very much
            • Originally posted by johnlewis1984 View Post
              Can you help me?
              Thank you very much
              Start with Don's TGSL 101 and coil doc.
              Upscale size and re-calculate number of turns required to obtain correct inductance of coils.
              Connect to TGSL TX circuit to check for proper oscillating frequency as per Don's document.
              Mount in housing and adjust Phase and Null.
                Can you help me?
                Thank you very much
                Hello. Measure the inductance of the receiving and transmitting coils of the one you have and make coils of any other size, adhering to the measured parameters.
                • Comment
                  • which loop is suitable for TGSL????
                    can GPX 5000 loop be used?????
                    • todas as respostas est?o no f?rum
                      • this detector is really not for beginners...I made about 5 copies
                        este detector realmente n?o ? para iniciantes... fiz cerca de 5 c?pias
                        • todos s?o dif?ceis e voc? realmente tem que ser um t?cnico em eletr?nica para saber como constru?-lo
                          • Eglish, please. Thanks.
                            • Originally posted by folharin View Post
                              5 times
                              it's better that you don't make it at all!!!
                                Which company metal detector loop is closer to TGSL loop in terms of inductance ???
