Originally posted by tiktak
I'm fine, thanks and you ? I think we can send our friend Ivconic best wishes as many already have done here.
About TGS things: you have iron-like stuff detection from 25cms ? wow ! I haven't on mine detector... I can disc out even big hammer of 500gr at few cm from search head.
I'm not sure about your problem but think there could be 2 causes:
- bad coil nulling that means it's easy picking up signal from a big mass even with disc on cause of easy overload
- something bad value in disc section or some mistake in circuit
I assume that 2 causes because I'm guessing your horse shoe is made of just iron: have you checked with different and large surely all iron stuff ?
I ask you cause steel alloys are much more easy to be detected cause they give different phase angles from pure iron; also plated things are detected e.g. zinc plated iron stuff ... you actually detect zinc layer instead of iron inside.
Make some test and figure out if horse shoe is a singular case or if with much other pure iron stuff it's all the same.
If you notice that horse shoe sound much easy and far away respect other stuff... there's maybe something that make detector sound more easy than with pure iron.
You must reach a tune of detector that null iron about totally but with just weak signal very near coil (e.g. at 1cm from bottom for an hammer head).
What to say... I also have craking sound with iron stuff... very often (not always) I can distinguish between them and real good targets.
That make me think you could have problems with disc section.
Let me know.
Kind regards,
Max
Impossible in most cases...
