gain gain gain
Hold the phone.
I just checked null signal amplitude at output of LF353.
Mine: 1.08 V pp
dfbowers: 1.42 V pp
Aside from fairly large null signal, it looks like dfbowers has higher gain by 40%. I thought I adjusted my C6 cap same as his using in-circuit capacitance measurements.
Well -- I can retrim my C6 to get approx same gain. I put in a crude trim and got my null signal up to 1.52 V pp.
Now I'm pretty sure my noise signal at LM308 output is higher than dfbowers, maybe 1.5X to 2X as high.
Why? is the question.
Is some of the noise oscillator noise? That could explain the difference. Of course dangling trim capacitors on my oscillator don't help that probably. But maybe it has more to do with the transistor or other components? Is my USB connector shabby?
Or is there some other reason for null voltage besides gain? Of course he does have a little more gain due to 4.7k vs. 5.1k resistors, which is a little different than adjusting resonance like I did.
Have to sleep on it, design more tests.
Hold the phone.
Mine: 1.08 V pp
dfbowers: 1.42 V pp
to calculate gain at output of U104 (LM308 DISC channel) for my PCB and dfbowers PCB.
