Originally posted by BKY1337
TGSL Tuning & troubleshooting
I tried both , DC and AC. I also checked the 2n2222a (T6). My Transistor tester said OK, NPN.
I measured 4 Volts DC at the collector of T6.
I get 900mv when i use DC at the tx connector to GND Battery. And only a few mV with AC.
I can measure about 14,5 khZ with the black probe at GND and without the red one.
I think i should get -16 Volts when the colpitts is working properly with 14,5 kHz.
Also the removing of the ics makes no change.
I think i have the steady sound because i dont have -16Volts but im not sure. The signal which comes from the 4024 to the audio section causes the sound. But im not sure. When i remove it, the detector becomes quiet.
Your oscillator is working. Yes, you are right about 4024. It is working too. I assume you have approximately -5V supply? Then I think maybe last 358 chip has gone bonkers. Try putting the other 358 chip in its place and see if constant tone disappears. Or check the three diodes.
Listen carefully, the constant tone in your speaker has nothing to do with your TX oscillator circuit. Your oscillator IS WORKING. MAKE SURE YOU HAVE -5V supply on circuit board. Measure this on pin 4 of any of the chips relative to ground(battery minus). This will tell you power supply is good, from this you can infer that your 4024 is good. Once you have good -5V supply(and +8V which I know you have), then you must look elswhere for cause of constant tone. Don't worry about the voltage amplitude at your TX coil right now, This will not cause constant tone in speaker.
I have +0.73 Volts DC at the Pin 4 . Then i think i should check the negative Voltage supply. I will do this tomorrow, it's late here in Germany.Originally posted by dbanner View PostListen carefully, the constant tone in your speaker has nothing to do with your TX oscillator circuit. Your oscillator IS WORKING. MAKE SURE YOU HAVE -5V supply on circuit board. Measure this on pin 4 of any of the chips relative to ground(battery minus). This will tell you power supply is good, from this you can infer that your 4024 is good. Once you have good -5V supply(and +8V which I know you have), then you must look elswhere for cause of constant tone. Don't worry about the voltage amplitude at your TX coil right now, This will not cause constant tone in speaker.
AH HA! There is your problem. You do not have -5Volts. look at tr7, tr8 , d6 and d7. That's your problem right there. Now as for TX voltage, it's supposed to be around 16 volt PEAK TO PEAK. Not -16 volts! I am going to measure voltage on my tgsl coil with cheapo meter and see what I get.
I measured 4.1 volts AC on my TX coil with cheap DMM. I know this is wrong. Pull up anode leg of D6, then check for -5V on this leg of D6. If you get -5V, then you have shorted component on board, if you don't get -5V, then you have to check 4024, TR7, TR8, D6, D7. I refer to this schematic when naming components.Attached Files
I dont have -5V at this Testpoint. I desoldered the upper Transistor (The 2N2907A) and my Transistor tester says damaged.
Both Leds are on PNP and NPN at my tester. I also saw that both transistors have a connection at their housings.
Is there a replacement for this transistor?
