Your noise please
Hi Simon ,
During some noise tests I found out that my LM308’s were not that good .
I’ve replaced them by a set of TL071 ( and for test purpose a set of TL081 ) and the results for my MD were great .
I’ve never had such an air depth
!! ( on test bench in workshop )
28-29 cm on a 1euro coin ( with some hums and cracks ), the Tx coil is shielded and the Rx is not shielded ,so here has to be more experimenting to be done .
The strangest thing is that the noise levels for all 3 sets of chips ( LM308 / TL071 /TL081) were almost the same , so what the problem was ….
Anyway : the noise level on U104 and U105 pin 6 with the Rx coil attached is about 20-30 mV for both channels. ( measured with scoop , didn’t get any reading on my DVM )
The DC offset voltage with the Rx coil not attached is I think +2 - +4 mV ( also measured with ancient scope ) for both channels .
This is very hard to see due to the residual voltage left ( 5-10mV ) even with pcb in a shielded box.
So perhaps here’s something to gain , lots of experimenting to done .
With an air depth of 28-29cm and sens setting at 100% I did get however some chatters .
Reducing the sens to 75 % the chatters disappeared and the air depth was about 22 cm.
I did not tried DFBowers mod yet , first I’ll try to get my TGS ( not the TGSL ) stabile .
Regards ,
Dennis the Mennis
Originally posted by simonbaker
Hi Simon ,
!! ( on test bench in workshop )28-29 cm on a 1euro coin ( with some hums and cracks ), the Tx coil is shielded and the Rx is not shielded ,so here has to be more experimenting to be done .
Regards ,
Dennis the Mennis
