please change all (program and schem & pcb )pic16f88 with PIC16F628A becuse i can not find it too.
IDX-PRO+VDI
Hi reza2195 !Originally posted by reza2195 View Postplease change all (program and schem & pcb )pic16f88 with PIC16F628A becuse i can not find it too.
Unfortunately, there is not possible to be used PIC16F628A, because that pic have not A/D converter onboard and enough program memory.
It could be used pic (16 or 18 series) with not less than 4k flash and A/D converter, in example PIC18F1320, or PIC16F690, but that will be not soon, due to my time free missing.
Regards.
VDI with IGSL
I've got it working with my IGSL, it seems to give about the right readings for different metals but I've not tested it outside yetOriginally posted by sido View PostHi, has anyone adapted this very interesting VDI project to other VLF detectors without visual meter or LCD and if so what was the outcome? Thanks.
Have to wait for my order from Silverdog till after Christmas and New Years.
Regards Sido
Thanks Kliner, so it works with the IGSL. That is good to here. Any others???
I would say the readings outside on soil might differ slightly to what you are seeing now.
Would the VDI give different readings for the same object, same depth but in different soils?
Regards Sido
hi holyuser,if you do it with PIC16F690 ,i wait for your good job.i,m from iran.Originally posted by holyuser View PostHi reza2195 !
Regards.
5x5 Two tones PCB
Hello people! I adjusted the final circuit made by Eduardo, to make it fit on a 5x5 sheet of fiber, which is the standard that I get in my city. Here I share it, maybe someone needs it.
RegardsAttached Files
Originally posted by Fabian View PostHello people! I adjusted the final circuit made by Eduardo, to make it fit on a 5x5 sheet of fiber, which is the standard that I get in my city. Here I share it, maybe someone needs it.
Good Job
With your permission I may use it, it will make for cheaper boards
Silverdog
