IDX-PRO+VDI
  • Originally posted by ampirate View Post
    Ok,
    Oscilliscope showed about 0.2V pp (yes 0.2V and not 16.0V !) at about 600hz-1000hz.
    I did tap downs of the ic components,
    and now I get a random squeaky sounds as I touch or wave my fingers around the TX leads.
    But the volume Pot does not work, and the audio is only a whisper.
    I am using a small 50ohm speaker 1/2W (could not find 32ohm) - should be close enough.
    Using 9v Bat - shorted over 7808 reg - so getting about 8v.
    What size capacitor did you add across the TX winding?
    Are you measuring with the oscilloscope as a meter does not work well
    • I am using an oscilliscope.
      But I have not attached the Coils yet.
      I did discover that the Battery was low, and had better and louder results with a new 9V battery.
      I dont have time at the moment to finish testing - with Oscilliscope and Coils - will do later.
      • to get 16volts pp you need a resonant coil cap combo. When the coil cap is connected it can function as a Tx.
        Then you will have a Tx to measure
        • Ok, on Oscilliscope, i have about 5V pp at about 1khz, with Coils.
          - I need to find the caps : 1mf and 0.033mf ?
            Yes
            1MFD TX and
            33 nF RX
            Use good quality otherwise they will drift in use
            They are part of the oscillator circuit so without them you will not be able to measure the TX peak to peak.
              Actually, I pulled the 7908 - and just shorted In to Out.I wanted to try with a 9V Bat first.
              to reduce chance of burning anything out. I read about 7.2V as actual Vsupply with V-Meter.
              But I am only reading 0.2V pp on the TX Pins anyway.
              The Wave is Bursts at about 600Hz-1khz.
              7908?
              • Could someone please check my numbers for me. I'm about to build my first coil for my IDX. I want a coplanar first and have used various internet calculators but I just want to be sure as I don't want to waste the copper. Here's what I've come up with (this is for a 30cm coil)...
                TX 587μH 30cm diameter 32 turns of 13AWG plus 15cm 8 turns 13AWG bucking coil 1μF cap
                RX 35.6mH 15cm diameter 337 turns of 38AWG 3.3nF cap
                Thanks, and this forum has been great for info for my build
                • Originally posted by Alphabetix View Post
                  use this data known to work very well
                  http://www.geotech1.com/forums/showt...ight=Idx+ccoil
                  • And RX 33nF not 3.3nF.
                    • Originally posted by akasyto View Post
                      33nf
                      • If you got 1kHz it sounds like you used the Rx coil and the 1uF for the Tx oscillator!!
                        • You need a 7808 not a 7908
                          • HI TO ALL ..Barry here from OZ, KOALA ,I am afraid I need to go back to the Drawing board on the China unit that I made a DD coil for it seemed to air test fair,, but not good in practice ..BUT not now I will have another go later down the track ..
                            STEVE ,,,The IDX is Great found a few bits of wire 22 shell-case alloy pop-rivett drilled-out bits [look like washers] etc,,,great on coins!!!! but only in my back yard !!! [Need to get out bush with it soon] ITS very quiet on my Red clay ground ,Better than my NEW whites GMT Also it has better steel rejection than the whites ..
                            The whites once getting the ground OK is better on small lead shot [I have no gold-nugget to test with ] very very sensitive..
                            WELL i am getting ready for a trip to Victoria [Gold-Fields] for 2-3 weeks Health permitting [been a bit crook] we will be off in 3 weeks ..
                            I hope to report some good finds of something ..??????????????????????
                            HAVE a great time out waving fella's ,,CHEERS,,,,,,,,,,,BARRY..
                            • hi, someone can tell me how to vary slightly RX frequency?
                              • hola a la soja Todos NUEVO Y La Verdad es Que no tengo mucha esperiencia, una versión si Alguien me Florerias facilitar, IDX-PRO + VDI completo, yo no tengo mucha Nociones de electronica, Pero me gustaria, intentar acer el Proyecto IDX-PRO + completo VDI. si Alguien me Florerias un yudar estaria muy Agradecido, ya Que en el foro this Toda la informacion Pero this fracionada, gracias y porfabor alludarme.
                                mi correo [email protected]
