Bipolar PI design
  • My suggestion is to use the const keyword to define constants that don't change during program execution​
    const uint8_t TXP_PIN = 9;
    const uint8_t TXN_PIN = 10;
    const uint8_t ADC_POT = A1;
    const uint8_t TCLKP_PIN = 2;
    const uint8_t GCLKP_PIN = 3;
    const uint8_t TCLKN_PIN = 4;
    const uint8_t GCLKN_PIN = 5;
    const uint8_t BCLK_PIN = 6;
    const uint8_t LED_PIN = 13;
    and of time constants​
    const unsigned long TX_PERIOD = 200;
    const unsigned long TX_WIDTH = 50;
    const unsigned long MAIN_DELAY = 15;
    const unsigned long MAIN_WIDTH = 10;
    const unsigned long GND_DELAY = 5;
    const unsigned long GND_WIDTH = 40;
ID:	434934 Hello, Carl, I will also try correcting the circuit with the CD4066, after which I copied the TL062 integral from the TDI circuit, and continued with your circuit, and from there I will continue with the TDI sound. There is also a potentiometer for thrash, what is your advice? Thank you.
      • See Eduardo's schematic, I think his threshold method will work.
        • I have good news and bad news.
          It's good that the finally 2 PICs arrived from a friend from a neighboring country!
          Incredibly "fast" and "expeditious" postal service!
          Between my place and my friend's place there are even incredible 160 km !!!
          It's a long way!
          When there are no clouds, my friend and I can literally correspond with smoke signals!
          In the days of ancient Rome, I remember, mail traveled much faster!
          These 2 PICs traveled longer than if my cousin from Mars sent them to me!
          Bad news; I'll have to delay porting the code and build the original first.
          I'm about to order pcbs from JLPcb.
          Click image for larger version  Name:	20250307_110917.jpg Views:	0 Size:	661.8 KB ID:	434947Click image for larger version  Name:	20250307_110946.jpg Views:	0 Size:	530.1 KB ID:	434948
          Click image for larger version  Name:	20250307_110950.jpg Views:	0 Size:	292.5 KB ID:	434949Click image for larger version  Name:	20250307_111124.jpg Views:	0 Size:	603.9 KB ID:	434950
          This is an excellent illustrative example of why I am so "successful" in this business and why I am literally sitting on "millions" earned from this business!
          (Things would be much worse if I didn't have good friends to help.)
          • Done!
            Click image for larger version  Name:	image.png Views:	0 Size:	85.9 KB ID:	434952Click image for larger version  Name:	jlpcb1.jpg Views:	0 Size:	185.7 KB ID:	434953​​​
            • They went crazy with postage and shipment!
              5 pcbs are $9.90 and $16.46 are shipping!
              It wasn't like that a few years ago.
              The overall world political situation is the cause of this.
              It's high time things to calm down and we get back to normal life.
                I'm about to order pcbs from JLPcb.​
                Well done - right choice.
                • Of course it is a better choice!
                  When something goes wrong; I have someone else to blame! (Carl)
                  • Thanks to Carl-NC everything is going well.
                    https://www.youtube.com/shorts/0nHaw6TbuWs
                    • Ok, until I get the pcbs from JLPCB, no reason not to try porting the code.
                      In the previous attempt, I did some things badly.
                      Now I already have a working version.
                      All that remains is to precisely set the time.
                      The matter is more complicated because a potentiometer was also introduced to adjust the frequency.
                      The code works. But it's still not tweaked to run the H-Bridge safely without risk.
                      The main problem I have is the lack of a multi-channel oscilloscope (the 10k and pulse merging trick doesn't work very well, due to overlapping critical times).
                      Currently, the frequency can be adjusted from 600Hz to 3kHz. But any change in frequency will affect the timing.
                      (Perhaps introducing frequency change was a bad idea but it is a tempting challenge)
                      It is recommended to test the code on the Arduino UNO platform without the rest of the hardware.
                      Colleagues who have multi-channel oscilloscopes; can help a lot here!
                      Code:
                       *  Bipolar PI metal detector by Carl Moreland
                       * Ported from PIC16F18426 implementation
                      #define TX_P_PIN      2   // Transmit positive pulse pin
                      #define TX_N_PIN      3   // Transmit negative pulse pin
                      #define CP_SYNC_PIN   4   // Charge pump sync pin
                      #define TGT_P_PIN     5   // Target sample positive pin
                      #define TGT_N_PIN     6   // Target sample negative pin
                      #define GND_P_PIN     7   // Ground sample positive pin
                      #define GND_N_PIN     8   // Ground sample negative pin
                      #define POT1_PIN      A0  // Potentiometer 1 (delay) pin
                      #define POT2_PIN      A1  // Potentiometer 2 (frequency) pin
                      // Constants
                      #define POT_AVE       8   // Number of samples to average for potentiometer readings
                      #define POT_SHIFT     3   // Shift value for averaging (divide by 8)
                      #define ON            HIGH
                      #define OFF           LOW
                      #define TRUE          1
                      #define FALSE         0
                      // Timing parameters (in microseconds, scaled by 8 in settings)
                      struct AppSettings
                        uint16_t txPeriod;  // TX pulse period (200-1000 μs)
                        uint16_t txWidth;   // TX pulse width (50-200 μs)
                        uint16_t tgtDelay;  // Target sample delay (10-30 μs)
                        uint16_t tgtWidth;  // Target sample pulse width (20-60 μs)
                        uint16_t gndDelay;  // Ground sample delay (5-20 μs)
                        uint16_t gndWidth;  // Ground sample pulse width (20-60 μs)
                      } settings;
                      // Timing values calculated from settings
                      struct TimingStruct
                        uint16_t txWidth;
                        uint16_t cpWidth;
                        uint16_t txDelay;
                        uint16_t tgtDelay;
                        uint16_t tgtWidth;
                        uint16_t gndDelay;
                        uint16_t gndWidth;
                      } timing;
                      // ADC variables
                      uint16_t pot1Array[POT_AVE];  // Running average array for pot1 (delay)
                      int8_t pot1Index;             // Current index in pot1Array
                      uint16_t pot1Total;           // Total of values in pot1Array
                      uint8_t pot1Value;            // Current averaged pot1 value
                      uint16_t pot2Array[POT_AVE];  // Running average array for pot2 (frequency)
                      int8_t pot2Index;             // Current index in pot2Array
                      uint16_t pot2Total;           // Total of values in pot2Array
                      uint8_t pot2Value;            // Current averaged pot2 value
                      // Interrupt state
                      volatile uint8_t intState = 0;
                      volatile uint8_t polarity = 1;
                      // Function prototypes
                      void initSettings();
                      void initTimers();
                      void updateTiming();
                      bool adcRun();
                      bool getPot1();
                      bool getPot2();
                      void clearSignals();
                      // Timer1 Compare Match A ISR
                      ISR(TIMER1_COMPA_vect)
                        // Reset the counter
                        TCNT1 = 0;
                        switch(intState)
                          case 0:  // Start of a new TX Pulse
                            OCR1A = timing.txWidth;  // Set next compare for TX width
                            if(polarity == 0)
                              digitalWrite(TX_P_PIN, ON);  // Turn on P-side MOSFET
                            else
                              digitalWrite(TX_N_PIN, ON);  // Turn on N-side MOSFET
                            intState++;
                            break;
                          case 1:  // Falling edge of the TX pulse
                            OCR1A = timing.tgtDelay;  // Set next compare for target delay
                            digitalWrite(TX_P_PIN, OFF);  // Turn off TX pins
                            digitalWrite(TX_N_PIN, OFF);
                            digitalWrite(CP_SYNC_PIN, ON);  // Toggle charge pump clock
                            intState++;
                            break;
                          case 2:  // Start of Target sample
                            OCR1A = timing.tgtWidth;  // Set next compare for target width
                            if(polarity == 1)
                              digitalWrite(TGT_P_PIN, ON);  // Turn on target sample
                            else
                              digitalWrite(TGT_N_PIN, ON);
                            intState++;
                            break;
                          case 3:  // End of Target sample
                            OCR1A = timing.gndDelay;  // Set next compare for ground delay
                            digitalWrite(TGT_P_PIN, OFF);  // Turn off target sample pins
                            digitalWrite(TGT_N_PIN, OFF);
                            intState++;
                            break;
                          case 4:  // Start of Ground sample
                            OCR1A = timing.gndWidth;  // Set next compare for ground width
                            if(polarity == 1)
                              digitalWrite(GND_P_PIN, ON);  // Turn on ground sample
                            else
                              digitalWrite(GND_N_PIN, ON);
                            intState++;
                            break;
                          case 5:  // End of Ground sample
                            OCR1A = timing.cpWidth;  // Set next compare for CP width
                            digitalWrite(GND_P_PIN, OFF);  // Turn off ground sample pins
                            digitalWrite(GND_N_PIN, OFF);
                            intState++;
                            break;
                          case 6:  // Before next cycle
                            OCR1A = timing.txDelay;  // Set next compare for TX delay
                            digitalWrite(CP_SYNC_PIN, OFF);  // Toggle charge pump clock
                            intState = 0;
                            polarity = !polarity;  // Flip polarity for next cycle
                            break;
                      void setup()
                        pinMode(TX_P_PIN, OUTPUT);
                        pinMode(TX_N_PIN, OUTPUT);
                        pinMode(CP_SYNC_PIN, OUTPUT);
                        pinMode(TGT_P_PIN, OUTPUT);
                        pinMode(TGT_N_PIN, OUTPUT);
                        pinMode(GND_P_PIN, OUTPUT);
                        pinMode(GND_N_PIN, OUTPUT);
                        analogReference(DEFAULT);  // default 5V reference
                        // Clear ADC signals
                        clearSignals();
                        // Initialize settings with default values
                        initSettings();
                        // Calculate initial timing values
                        updateTiming();
                        // Initialize timers
                        initTimers();
                      void loop()
                        static bool adcFlag = false; // Single flag for ADC state
                        if(intState == 1)
                        { // Idle state
                          if(!adcFlag)
                            if(adcRun())    // Read pots and update if values changed
                              updateTiming();
                            adcFlag = true; // Mark ADC as checked
                        else
                          adcFlag = false;  // Reset flag when not in idle
                      void initSettings()
                        // Initialize timing settings (all in μs, scaled by 8)
                        settings.txPeriod = 200 << 3;  // 200μs -> 5kHz
                        settings.txWidth = 50 << 3;    // 50μs
                        settings.tgtDelay = 15 << 3;   // 15μs
                        settings.tgtWidth = 10 << 3;   // 10μs
                        settings.gndDelay = 5 << 3;    // 5μs
                        settings.gndWidth = 40 << 3;   // 40μs
                      void initTimers()
                        // Stop interrupts while setting up
                        noInterrupts();
                        // Setup Timer1 (16-bit timer)
                        TCCR1A = 0;
                        TCCR1B = 0;
                        TCNT1 = 0;
                        // Set compare match register
                        // Turn on CTC mode
                        TCCR1B |= (1 << WGM12);
                        // Set CS10 bit for no prescaler
                        TCCR1B |= (1 << CS10);
                        // Enable timer compare interrupt
                        TIMSK1 |= (1 << OCIE1A);
                        // Re-enable interrupts
                        interrupts();
                      void updateTiming()
                        uint16_t tmp;
                        // Convert microsecond values to timer counts
                        // Arduino runs at 16MHz, so each count is 0.0625μs (with no prescaler)
                        // Multiply by 16 to convert microseconds to timer counts
                        // Calculate TX pulse width
                        timing.txWidth = (settings.txWidth >> 3) * 16;
                        // Calculate target sample delay
                        timing.tgtDelay = (settings.tgtDelay >> 3) * 16;
                        // Calculate target sample width
                        timing.tgtWidth = (settings.tgtWidth >> 3) * 16;
                        // Calculate ground sample delay
                        timing.gndDelay = (settings.gndDelay >> 3) * 16;
                        // Calculate ground sample width
                        timing.gndWidth = (settings.gndWidth >> 3) * 16;
                        // Calculate charge pump width
                        tmp = (settings.txPeriod + settings.txWidth) >> 1;
                        tmp -= settings.tgtDelay + settings.tgtWidth + settings.gndDelay + settings.gndWidth;
                        timing.cpWidth = (tmp >> 3) * 16;
                        // Calculate delay to next TX pulse
                        tmp = (settings.txPeriod - settings.txWidth) >> 1;
                        timing.txDelay = (tmp >> 3) * 16;
                      bool adcRun()
                        if(getPot1() || getPot2())
                          // Update settings with corrected scaling for tgtDelay
                          settings.tgtDelay = (50 + pot1Value) << 3;  // Fixed: shifted by 3 instead of 1
                          settings.txWidth = (50 + pot2Value) << 3;
                          settings.txPeriod = (200 + (pot2Value << 2)) << 3;
                          return TRUE;
                        return FALSE;
                      bool getPot1()
                        uint16_t potValue;
                        static uint8_t oldValue = 0;
                        // Read and scale potentiometer value (0-1023 to 0-63)
                        potValue = analogRead(POT1_PIN) >> 4;
                        // Update running average
                        pot1Total -= pot1Array[pot1Index];
                        pot1Total += potValue;
                        pot1Array[pot1Index] = potValue;
                        // Increment index with wrap-around
                        if(++pot1Index >= POT_AVE)
                          pot1Index = 0;
                        // Calculate average
                        pot1Value = pot1Total >> POT_SHIFT;
                        // Check if value changed
                        if(pot1Value == oldValue)
                          return FALSE;
                        oldValue = pot1Value;
                        return TRUE;
                      bool getPot2()
                        uint16_t potValue;
                        // Read and scale potentiometer value (0-1023 to 0-255)
                        potValue = analogRead(POT2_PIN) >> 2;
                        pot2Total -= pot2Array[pot2Index];
                        pot2Total += potValue;
                        pot2Array[pot2Index] = potValue;
                        if(++pot2Index >= POT_AVE)
                          pot2Index = 0;
                        pot2Value = pot2Total >> POT_SHIFT;
                        if(pot2Value == oldValue)
                          return FALSE;
                        oldValue = pot2Value;
                        return TRUE;
                      void clearSignals()
                        // Initialize the running average arrays for potentiometers
                        pot1Index = 0;
                        pot1Total = 0;
                        for(int i = 0; i < POT_AVE; i++)
                          pot1Array[i] = 0;
                        pot2Index = 0;
                        pot2Total = 0;
                          pot2Array[i] = 0;
                      • For code readability I used Cpp directives.
                        However, in the final version it is preferable to replace them with direct port&pin manipulation.
                        Because the execution speed will be higher than 12x to even 40x !!!
                        I plan to do that in the final version once everything else is checked and set up.
                        • New toy, arrived yesterday:
                          • I assume the "hiccup" on the oscillogram is due to the USB power supply.
                            I didn't feel like checking because it's good enough as it is.
                            • While I wait for the pcbs to arrive...
                              • Zero percent's of what? The software some times gives slightly strange massages at first view.
