BARACUDA-Legend-1
  • Hi folks,
    I've had coils produce audible sound on both Bara and SP machines. Seems to be loose windings, shield or coil housing. Never had a problem with the -5v rail or a 40106.
    Cheers, Jim.
    • 40106 is sensitive to electrostatic. It's just one touch of the finger to be damaged or completely destroyed. Attention must be paid to electrostatic protection.
      • Bara working
        Hi all, Replaced the 40106 and solved problem with low -5 volt supply. Bara is working stable now with good sensitivity with test coil. I picked up some 22 gauge Teflon silver 7 strand to make fast coil. will post results after testing.
        Thanks to all for you input to help solve my problem. It takes good people to make a great forum and that's what we have here Geotect !
        Best Regards.
        • Bara air test results
          Hi all, Here are the test results of my Bara with a good coil. (air test)
          Canadian coins
          $1 looney- 30cm
          25 cent - 25cm
          10 cent - 19cm
          5 cent - 20cm
          1 cent - 18cm
          jar lid - 40 cm
          soda can 50cm+
          Test where indoors in not ideal conditions, lots of metal near by.
          Can't wait to use the Bara on the beach this summer. I think I'll be digging some deep holes
          Still have some tweaking to do however I'm happy with the results
          • little heat problem
            hello
            with my last coil
            i got good results 2€ coin up to 20cmand good pinpoint
            but tip127 gets hot after 1minute
            with other coils no problem (but other have more micro Henry)
            the resistance of that coils is similar like some others i build
            this coils also make a summing sound i have some others with a lower L here they sing also but with other pi detectors too
            is this a sign that the inductivity is too low?
            need the tip127 a minimum of inductivity (coil works here also as a choke?)
            in this case i would add a second layer to my planar coil
            or have i only to add a resistor or something else when i use a low "L" coil?
            regards bernds
            • Hi bernte_one. What diameter wire you use for your last coil? Litze LIY 0.5mm?
              • Here is some good info on Litz wire.
                • Originally posted by maikl View Post
                  hello
                  its LIY Litz H05V-K 0,5mm
                  regards bernd
                  • Planer inductance
                    Hi Bernte One, What is the inductance of your planer coil? Did you vacuum form the coils in your pictures you posted? looks very nice !
                    Best Regards,
                      hello
                      with my last coil
                      regards bernds
                      130uH sounds a bit low, not much resistance for tip127, so maybe thats why its getting hot ?
                      very nice coil construction, how did you get it so neat ?
                      • hello
                        low resistance- thats one thing i thought too- maybe i try a resistor 1R5 in serie with coil?
                        the shells are vacuum formed- the only trouble i have everytime is to cut clean lines in the wood plates
                        the coil is glued on a paper sheet with spraying glue
                        first spray a thin layer of glue and wait two minutes
                        the lay down the wire
                        when ready press it betwenn two plates with a weight on (i use wood plates)
                        next i try is a basket coil like for the chance pi
                        and a simple dual field
                        if anyone has an idea what i can do better on my simple planar coil please post
                        thanks bernd
                        • Hi Bernd. You have no problem with low resistance (original Barracuda coil resistance 1R5) you have a problem with low inductance coil. My advice is to build a another similar coil, that'll put through the first and connected in series. You'll get the coil inductance 260 uH and resistance of 3.4 ohm. For this type of coil is probably better to use wire with a solid core (0,7mm-0,8mm) rather than Litz wire (due to less resistance). See the link below at the bottom http://fandy.vov.ru/Chance.htm
                          • thanks maikl
                            that was the answer i hoped to get
                            this evening i have a little bit of time
                            will post results later
                            thanks all for help
                            • "How To" accurately ID iron with Baracuda.
                              This is not 100% reliable, but keep in mind, neither is the best IB detector in the world.
                              Running with a 9" mono coil at normal sweep speeds and a 25us delay, all targets sound the same. But wait! Try slowing your sweep speed and listen to how targets respond.
                              If it does not work, change sweep angle by 90 degrees. Items that can be magnetized can be easily identified by sweeping your loop parallel to the longest dimension of an iron or steel object. This works no matter how far away the object is from the loop.. as long as it is still in detection range.
                              Some possible exceptions are, but not limited to:
                              Thick, round steel items like a 5/8" nut. Still sounds like a good target.
                              Thin steel on edge can still respond like a good target.
                              A gold ring on its edge will respond with a double beep one way at slow sweep speeds but not at all from 90 degrees.
                              The 3 targets at the bottom are, a lead bullet, a coin and a brass rod.
                              The 3 targets at the top are a nail a block of steel and a fender washer.
                              Do not under estimate the power of this simple and deep detector..
                              Enjoy.
                              Don
                              • the coil is glued on a paper sheet with spraying glue
                                Thanks for the tip with the spray glue, will give it a try
