Threshold Pot doesn't work
    I don't understand. What are the amplitudes?
    I am using such wiring for making DD
    • Nulling a coil for PI and IB are done the same way: when you have proper IB ther should be NO SIGNAL on the RX coil, or at least a minimized signal. Your "No Target" signal in post 551 shows a huge signal, which means the coil is not nulled. It should be very small like the first signal in Fig. 26-15.
        Thank you.
        I can not understand fig. 26-15. Is that inside of your book?
        • Yes. You want to adjust the coil overlap until the RX signal is close to zero.
            Now, i tried, the best form is like follows
            • That looks better. No try different targets.
                Now i tested.
                It is no target:
                Click image for larger version  Name:	notarget.jpg Views:	0 Size:	122.2 KB ID:	443882
                I captured a video from moving Nail
                https://drive.google.com/file/d/1gD3...ew?usp=sharing
                And captured second video from 1euro coin
                https://drive.google.com/file/d/1moW...ew?usp=sharing
                I have never tested such nulling coil over PI.
                Do you think such nulling is as sensitive as normal DD in PI?
                Please forgive me for my annoying.
                Is it possible help me about adding your suggestion schematic for blanking audio?
                Thank you.
                  For better understanding, i captured with bigger targets.
                  Iron Hammer:
                  https://drive.google.com/file/d/1jiM...ew?usp=sharing
                  Aluminum bottle
                  https://drive.google.com/file/d/1S30...ew?usp=sharing
                  Now, I think discrimination is clear.
                  • It looks like you are getting decent results. Now you can add the demodulator and figure out what timing gives you a reasonable signal. After that, figure out what you need to do with it to blank the audio or use a low tone. I can't tell you how to do this because I have not done it myself.
                      Thank you dear Carl for your valuable tips and supporting.
                      I will find the best location for sampling.
                      But for starting to real test, can you give me a primary schematic in order to adding inside the box (attached)?
                      In fact, i have manually built TX+preamp+DiscDemod on a small board.
                      Now, i want to play next part schematic (blanking, inside of box).
                      I have a proposal, i hope you accept it. Please suggest me your initial or proposed schematic for the box but its output is a simple led for only Iron detection.
                      Then, I will play it and will find the best result (best sample).
                      After finding the best result , finally we (with your supporting) change its led output to 2n3904 for blanking.
                      I hope you accept it, i am ready to test or to play all of your suggestion.
                      Thank you.
                      Click image for larger version  Name:	demod.png Views:	0 Size:	651.6 KB ID:	443891
                      • The simplest solution is to place a comparator after the demod stage and have the open-collector output drive a series resistor and LED (connected to +5V).
                          Thank you.
                          Is that correct?
                          In my schematic, ground is +VB.
                          Do you think i should connect pin4 of lm393 to gnd (+VB)?
                          • Yes. You may need to reverse the inputs depending on whether iron gives a high signal or low signal. I would use -5V for pin 4.
                              Hello
                              Dear Carl
                              Today, i tested the LED shower (my DISC schematic is based on #567 post), but i have not any reaction for ferrous or non-ferrous on led. I think the changing is very very very low and lm393 can not show.
                              But i can see increase/decrease TX pulse for ferrous/non-ferrous on scope.
                              First i adjusted my sampling as follow:
                              Click image for larger version  Name:	1.jpg Views:	0 Size:	132.0 KB ID:	443977
                              And i checked my Demod output as follow:
                              Click image for larger version  Name:	2.jpg Views:	0 Size:	133.6 KB ID:	443978
                              No reaction with LED.
                              Again, i changed my sampling so that my demod output is a tringle:
                              Click image for larger version  Name:	3.jpg Views:	0 Size:	131.1 KB ID:	443979
                              Click image for larger version  Name:	4.jpg Views:	0 Size:	133.9 KB ID:	443980
                              But no result with LED.
                              No matter how hard I try, my output shape doesn't get any better than this triangle.
                              I am sure that my LM393 is true. My LED will turn on if i change pot (lm393).
                              • Show me the waveforms for TP8, U6-pin8, and U6-pin14 with no target.
