  • Originally posted by Olly View Post
    Here is the documentation package of the board. The PCB is 4 layers which I had made at JLC PCB for $28 for 5 boards.
    Please note that the 470 Ohm resistor R4 must be replaced by 2 x 1K 0805 resistors soldered on top of each other as the single 0805 470 R resistor is incapable of handling the power and fails...
    [ATTACH]n436354[/ATTACH]
    I also kept the PIC as a DIP device for ease of reprogramming.
    Kind regards
    It has the zip with the files for the PCB
    • Originally posted by Boadil View Post
      Inside the .zip file is a sub-directory called 'gerbers', these are the PCB manufacturing files.
      Just zip up this 'gerbers' directory and send it to JLC or wherever you plan on having the boards made.
      Note that the gerber naming convention is as defined by JLC (They have a guide on their website for producing gerbers from KiCad the way they like it.)
      Cheers,
      • Will it work if another integrated circuit is used instead of LM318, for example, LF356 or LF411?
        • The LM318 has a higher bandwidth and slew rate than the LF356 or LF411. LM318 = 70V/microsecond vs 12-13V/microsecond for the others.
          No idea if "it will not work" because of this... I never tried.
          • Hello F117 master,
            What should be the coil wire thickness and mh value information for an 18 cm sensor?
            Thank you very much
            Gurdal
            • gurdal
              You can find plenty of information on coil / wire sizes in the dedicate coil section of this forum. https://www.geotech1.com/forums/forum/technology/coils
              A coil for Pickini v4 is not different from any other generic PI coil.
              Inductance: 300 - 400 microHenry --- resistance 1 - 3 Ohm
              Here is some info on my hands-on coil build:
              • According to this post by MartyJ1963 -- a basket coil would give best results.
                I never tried it myself:
                https://www.geotech1.com/forums/foru...544#post259544
                • Thank you very much
                  • Can you help me please as I am in new territory. I have the V4.2 source file and hex file here at PICKINI PI Detector but they both appear to be text files. How do I get them from the web site and convert them into something my Picket3 can use? Alternatively, if anyone already has these files in a useable format, would you mind sharing?​
                    • Simply with copy and past into a texteditor
                      • MartinB
                        The file format is Intel Hex. This is indeed a text file that can be interterpreted by a programmer that supports this format.
                        Pickit3 can import this file -- eg via MPLab. I still use a very old version in combination with PicKit3.
                        In MPLab: File -> Import -> select the Pickini hex file.
                        • Hi F117 and GeoMax,
                          Thank you both for your assistance. I was really overthinking what turned out to be a very simple process.
                          • Even after all these years, it remains an interesting project that offers a lot of possibilities from its source file, allowing you to change parameters and fine-tune it to the maximum.
                            • @Boadil
                              Glad you still like it 10 years later.
                              You could still improve it:
                              - adapt the main slicing level of the comparator with an an analog ground sample to introduce some sort of automatic GEB
                              - port it to a newer Microchip microcontroller
                              - preferably one with an internal clock speed higher than 32 MHz = more resolution to measure the pulse width
                              ​- port the code to the Microchip IDE instead of the MikroC environment I used at the time
                              - draw a new PCB with Kicad or some other up to date tool
                              - possibly introduce 2 different slicing levels for the comparator to get some idea of the slope and possibly some sort of rudimentary discrimination based on conductivity
                              I tried porting the Pickini4 code to an Arduino Nano once, but it lacked all sorts of nice features that were present in the 16F1824: speed, lack of comparator hysteresis, ADC resolution and speed, ...
                              Feel free to give this project a new life - or temporal sampling in general.
                              Best regards from Belgium,
                              - Bernard
                              • UNFORTUNATELY THE WEBSITE IS NOT AVAILABLE ANYMORE​
