Originally posted by nelson
Original DP has a coil of 1.1 x 1.1 m with 16 turns. If you will make it 1x1m then wind 17 turns. Use wire with 1mm diameter. If the DC resistance is lower than 2.5 Ohm then connect a resistance in series, so to measure at the connector a dc resistance of 3.5 ohm (3 ... to 4 ohm is ok).
