Last version with merged mods from Max.
I used i slightly diferent path.
From now on i will only mod the last posted layout,so we dont have 2 diferent versions.Also a list of mods made would be usefull each time.
Here beside small details, i used a jumper to "B" connection and changed value of resistor from U12/12 to 27K instead of 22k .
regards,
Fred.
RELIC HAWK
Hi my friend.
Could you please send me a copy to [email protected] or to [email protected]
In advance many thanks
Nelson
Originally posted by amtech2005 View PostNakky , Sprint 5.0 open's Relic Hawk perfect. If you need a copy of sprint 5.0 , I can e-mail to you...................Take care................Eugene
Ok yes Max,Originally posted by Max View PostHi Fred,
not big mistakes just that at U12 and trimpots you made no connections to -2.5 and +2.5 or pads but I've used your layout, my idea is always we all use same pcb at the end... so why don't use last version and just mod it more ?
I've made that changes but would be really good if you will check pcb layout and spot if I missed something along the way...
Kind regards,
Max
yesterday night i made a lot of small corrections , nothing important but rounded corners etc. ,i will post it here soon with your mods.
thanks,
see you,
Fred.
Hi Fred,Originally posted by Fred View PostHi Max,
thanks,
I have been improving my version too,most are small details, did you make big changes or found importnant mistakes so i can correct them too ?
So we don´t end with two very differents PCB
regards,
Fred.
Kind regards,
Max
Hi Max,Originally posted by Max View PostHi,
I've made some mods... added -2.5 and +2.5 rails + connections.
Changed some pads to bigger ones and checked a bit...
I think there could be some other mistake... so better check well first.
Kind regards,
Max
thanks,
regards,
Fred.
Kind regards,
MaxAttached Files
RELIC HAWK
I Put the parts list in a note-pad . So its easy to move around, also easy to correct...........EugeneAttached Files
Yes Nakky, i have used Sprint 5.0.
A shame they are not compatible.
Fred
RELIC HAWK
It make sense to mee too that if it is marked "102" , (1000), that it will be 1mH...but as Max said can not be taken for sure.
I send here the completed (but still probably contain errors)PCB , with upper side layout.
It is was more dificult than expected to do, so it would be good if someone could carefully check it.To do so i send also the Sprint layout file,otherwise it is almost impossible.
My head is spinning already and i must make a pause.
I made only a very quick verification, so it may be missing some connections.
Unfortunetely, the +/- 2v5 connections to the pots still must be hard wired.I could have done differently but it would be more confusing , in particular for those who want to make it single layer.
Maybe that can be improved later.
Any suggestion is welcome.Critics too!
Best regards,
Fred.Attached Files
Hi,Originally posted by KingJL View PostI would consider studying the possibility that it is 1 uh. Other ML detectors use 1 uh in series with the RX coil path (i.e. SD2000). I know the SD2000 is a completely different type detector, but ....
J. L. King
well I'm not absolutely sure it's 1mH... but usually I read 102 as 1mH. It could also be 1uH inductor there... depending on units used for indication... e.g. if inductor is a small value one value could be also expressed in nanohenries really... though a bit rare option.
I now the great part of inductors are all similar about that and value is expressed in uH.
PS: I still think it's 1mH... but let's see other schematics too...
Kind regards,
Max
I would consider studying the possibility that it is 1 uh. Other ML detectors use 1 uh in series with the RX coil path (i.e. SD2000). I know the SD2000 is a completely different type detector, but ....Originally posted by Max View PostHi,
yes it is: 102u = 10 * 10^2 uH = 1000uH = 1mH
At least I read it as this...
(actually the u is a "K" but change nothing...)
PS: in the bulgarian schematic I see 1uH there... but probably is a mistake cause if it's 102k the only way it could be 1uH is if unit used are nanoHenries...
Kind regards,
Max
J. L. King
Hi,Originally posted by KingJL View Postwhere? I see 102u in the schematic, is this the one?
J. L. King
(actually the u is a "K" but change nothing...K -> tolerance =+-10%)
Kind regards,
Max
this is bill of materials I've made from schematic...
74 resistors... it's a huge monster !
Here it is:
value quantity
resistors
2k2 2
15k 1
470R 1
100R 2
4K7 4
27k 6
47k 10
6k8 2
4M7 1
18k 3
820k 1
330R 4
33k 1
360k 4
10M 5
1M2 1
2M2 1
22k 5
1M6 1
620k 1
100k 11
68k 2
10k 2
91k 1
470k 1
47R 1
capacitors
220n 5
6n8 1
100n 32
10n 4
1u 3
1n 6
2n2 2
4u7 16v 1
470u 16v 3
2u2 16v 1
470n 4
trimpot
10k 1
100k 3
pot
10k 2
100k 1
diodes
1N4148 7
LM336 2.5v 1
S400/1N4007 1
transistors
bc557 2
bc547 1
bc517 1
inductorswhere? I see 102u in the schematic, is this the one?1mH 1
Regards,15mH 1
ic
cd4024 1
cd4053 1
cd4066 3
ts27m2 3
ts27m4 1
lm339 1
lm393 2
ne5534 1
Kind regards,
Max
J. L. King
