RELIC HAWK
  • tiktak
    Hi
    Sory I dint mean to harm you.
    I am not Guru!And best in world...........
    Ivica and Max ARE GURUS FOR SHORE!
    But with me this are only letters.
    I will be very happy to see your work.And this will save me a lot of frustration.I also wanna make full copy like you.But my skills dont alow me to solder SMD yet.So I wanna make working device that is near original RH performance.
    Hope you made progress soon.
    Take care.
    p.s.just preparing this test PCB I have reached this point and wanned IVCONICS opinion.
  • amtech2005
    RELIC HAWK
    TIKTAK, BESIDES YOURSELF MANY ARE WORKING ON THIS SCHEMATIC RIGHT NOW AND THEY ARE ALSO ELECTRONIC GURU EXPERT'S , THE BEST IN THE WORLD ON DETECTOR DESIGN AND REPAIR !!!!!! ANY DAY NOW THIS RELIC HAWK WILL BE READY!!!TAKE CARE..............EUGENE
  • tiktak
    Ivica can you tell me what values to try in red circles?
  • tiktak
    Did anyone labeled ICs on last schematic right?
  • amtech2005
    RELIC HAWK
    IF ANYONE HAS CLEAR PHOTO'S OF THIS .PLEASE E-MAIL ME . THANK-YOU.......EUGENE [email protected]
  • Unregistered
    Guest replied
    QUOTE:
    "ALSO I READ THE DEPTH COMPARISON OF THE TWO IS ALMOST IDENTICAL !!!!!! "
    This is to be expected with COINSEEKER 2 PRO.
    Compare the 2 circuit diagrams of COINSEEKER 2 PRO and RELIC HAWK.
    The resistor and capacitor values that are changed by "OPERATION MODE" switch ("LMS" switch) are the same in COINSEEKER 2 PRO as having "LMS" switch on RELIC HAWK set to "L" mode allowing for detection of large, deep targets.
    Not good for small, shallow targets etc...
    If you add on other changes done to COINSEEKER 2 PRO then this is reason for unhappiness with COINSEEKER 2 PRO.
    I will wait for RELIC HAWK !!!
  • amtech2005
    RELIC HAWK
    I HAVE BEEN COUNTING CAPACITORS AND RESISTORS ALL DAY . "A BIG DIFFERENCE BETWEEN RELIC HAWK ORIGINAL AND COIN-SEEKER 2 PRO" !!! IT IS REAL FUNNY THAT MINELAB ADVANTAGE IS 5 KHZ AND ALSO THE CIRCUIT BOARD IS VERY CLOSE IN SIZE TO THE COIN-SEEKER 2 !!! ALSO I READ THE DEPTH COMPARISON OF THE TWO IS ALMOST IDENTICAL !!!!!! I THINK COIN SEEKER 2 PRO IS NOT EVEN CLOSE TO RELIC HAWK. I COUNTED OVER 110 RESISTORS AND CAPACITORS ON RELIC HAWKS FUZZY PHOTO , AND ONLY 26 CAPACITORS ON COIN-SEEKER 2 . I WILL BE WORKING ON THIS FOR AT LEAST A FEW WEEK'S ......... AND THEN A PCB BOARD.. ..............EUGENE
  • amtech2005
    RELIC HAWK
    GEO, I WILL SEND IT ASAP ,IT IS SMALL ABOUT 1.5 MEGA-BYTES . BUT I THINK YOU HAVE MOST OF THE INFORMATION ALREADY. I ALSO HAVE ABOUT 3 OR 4 FULL DISKS OF ABOUT 2 GIGA BYTES OF DETECTOR SCHEMATICS , PHOTOS , PDF FILES OVER THE LAST 3 YEARS ,BUT THEY ARE ALL MIXED UP AND NOT IN ANY ORDER , A BIG MESS !!!! . WHEN I GET TIME I SURE WOULD LIKE TO COPY THEM TO PAPER AND PUT THEM IN A FOLDER AND LABEL EACH ONE.. ANYWAY I WILL SEND YOUR SMALL FILE , AND THEN I WILL BE VERY BUSY FOR A FEW DAYS WORKING ON THIS RELIC HAWK ALSO !!! TAKE CARE..............EUGENE
  • Geo
    OK Eugene.
    I sent to you my email
  • amtech2005
    RELIC HAWK
    GEO, IT MUST BE A THROUGH-HOLE AND IT MUST NOT BE THE "COINSEEKER 2".. COINSEEKER 2 HAS LOST DEPTH BECAUSE THEY DOWN-SIZED AND CHANGED THE SCHEMATIC. AND CHANGING THE AUDIO DID SOMETHING TO THE CIRCUIT GAIN . THEY ALSO TOOK AWAY ALL CONTROL SWITCHES. I AM JUST STARTING THIS PROJECT, SO PLEASE BE PATIENT.SEE POST #53 AND POST#59 ON THIS PAGE OF THE RELIC HAWK , AND SEE THE SIMILARITIES AND SEE WHAT IS MISSING. I AM A GOOD ELECTRONIC REPAIR TECH ON REPAIRING EXISTING DEVICES .BUT NOT A DESIGNER AND I AM NOT A SCIENTIST !! YET. I DO HAVE 2.0 MEGABYTES OF PHOTO'S AND FILES ON RELIC HAWK I CAN E-MAIL TO YOU, BUT THEy ARE JUST BITS AND PIECES OF FILES. I WILL START ON THE PARTS LIST TONIGHT AND TOMMORROW. ANY PROBLEMS I WILL LET YOU KNOW AND KEEP YOU POSTED. ........THANKS..............EUGENE
  • Geo
    Hi Eugene.
    I am waiting for the parts list. I want to check it.
    It is long time that i did not make anything, so i want to try to help you to design the pcb. Ivica and Max have made a lot of things at this forum so it is our time
  • amtech2005
    RELIC HAWK
    WHEN I WORKED ON BROADBAND AMPLIFIERS FOR CABLE TV , NO ONE TAUGHT ME HOW TO WORK ON SURFACE MOUNT PROCEDURES AND I HATED IT.WHEN I FIRST GOT STARTED I USE TO BREAK SMT'S WITH TWEASERS, ALSO OVERHEATED THE SMT DEVICES AND THE FOIL ON THE BOARD.IT TOOK ME TIME LEARNING THE HARDWAY AS USUAL. BUT ANYWAY I THINK THE NUMBER ONE PURPOSE OF SMT IS SAVING SPACE AND ALSO IT HAS LESS STRAY CAPACITANCE AND STRAY INDUCTANCE PROBLEMS. NOISE PROBLEMS HAUNTS US ALL , IF YOU COPY A PERFECT WORKING PCB CIRCUIT BOARD "THE PART LOCATION'S "MUST BE IDENTICAL" TO THE ORIGINAL PART'S LOCATION OR YOU WILL HAVE EXTRA PROBLEMS THAT YOU DON'T NEED!!! LIKE THE ORIGINAL GOLDEN SABRE HAS GREAT DISCRIMINATION AND IT'S DEPTH IS VERY GOOD. AND IF THE NEW CIRCUIT BOARD'S BEING MADE ARE IDENTICAL TO THE ORIGINAL GOLDEN SABRE PCB BOARDS THEN THE NOISE PROBLEM IS A FAULTY COMPONENT OR COMPONENT VALUE OR THE SEARCH-COIL IS NOT RIGHT. THANK-YOU MAX , IVCONIC, GEO, AZIZ,CARL, TINKERER, THE WIZARD, AND EVERYONE FOR HELPING TO MAKE GEOTECH FORUM AND HOBI-DETEKTORI FORUM SO GREAT!!!!!!!!!!!!..............TAKE CARE ALL.......................EUGENE
  • Max
    Luck, i dont have problems with my eyes.... , but my skills over smt are very poor ..., so me too - i would like to see here accurate through hole pcb. Dont have enough time to draw one, right now...
    Regards!
    we must consider also many people here have just "normal/old" components kind not smd. So the good idea is making first a throughole design... so different people will start building it and find bugs if any... start tuning etc etc and we'll spot problems easy with such a design.
    Then if someone need smd that could be made as alternative design to keep things smaller and lighter... but just after end-up with device working.
    Personally I still prefer old style than smd cause not only eyes stress but about the fact removing stuff from smt board is not as easy (sometimes is painful experience) as with old stuff... so to experiment...change stuff, try different is better having e.g. old style passive components and sockets for ics etc etc
    I'm sure you agree with me on this...
    Kind regards,
    Max
  • Max
    Max you are reading my thoughts! I was going just about to suggest same solution to be tested with TGS on TGS thread!
    As i posted earlier, there is certain relation between some ocassional chatters and choice of speaker at TGS. With 16 ohms speaker TGS have less and rare chattering than with 8ohms. Even more, if you put extra 10 ohms resistance in serie with speaker those chatters will disapear for good, but audio will be very mum and weak. So first time i spotted this at Relic Hawk, i wandered what would be if....
    Worth of trying!
    yes I think too it's worth cause I noticed too that lower impedance speaker give problems. I find so far just some 16ohm speakers works fine on tesoro's (bandidoII and tgs) and just a few of 8ohm speakers could be used really on them cause of chatters appears.
    I have maybe 100 different 8ohm speakers and maybe (not tested 100!) just 20-30% seems are usable on tgs cause larger ones gives problematic behaviour... chatters.
    Probably the oscillations of coil in the permanent magnet area is sustained too much in larger ones and that produce at 8ohm too much troubles on supply rail. On some smaller I noticed problems are less but still there.
    I think the filter is a good idea but then we must use an headphone I think cause we also reduce signal strenght cause of resistance etc
    Anyway, it's something that probably will make even more stable tgs than it is already.
    Kind regards,
    Max
  • Max
    Worth of trying!
    Kind regards,
    Max
