Originally posted by kt315
TESORO GOLDEN SABRE
Foma.
Obyasni please, chto eto dast na praktike? Est' uvelichenie glubini obnaruzheniya bez raspada signala.[/quote]
I have done so on its detector. The Range of the regulation to sensitivity more.
But earlier were a spurious signals, which I could not take away.
If enlarge R44, maximum sensitivity will less.
Modification
This is mine finally version. Work very well , one silver denar detect at 30 cm.
Best regardsAttached Files
no need to draw what you change in schematic. comparators are working like to YES-NO. you have killed the sensitivity. get back the tuning.Originally posted by FOMA View PostWhere what instability? No problems with stability.
It Is Changed frequency of the generator-is changed frequency in receiving winding.
No problems. No need nothing draw.
Foma.Originally posted by FOMA View PostHi all.
So will better.
the generator is a cause of yet one unstability. still you need TO get absoliute stability in all parts of the schematic, as highter as possibly. notwithstanding you have a full right to go from Classic to 5900 di Professional, step-by-step, tearching and getting all tiny details you did not wish to take attention on at start point and later. it is only YOUR way on staircase leading you up in mind. yep you will get all these knobs... but you will be sure great guru...
So bad. Golden, Eldorado, Silver has one sensor.
And generator is adjusted under frequency of the sensor.
But that is offered nonsence.
simonbaker, could you to simulate up-dated one?Originally posted by simonbaker View Post
So I simulated the circuit and adjusted the TX oscillator amplitude to grow slowly, and at a certain value I see the "jaggies" appear just before the LF353 inputs become saturated.
I hope it will good.
YOURSAttached Files
The scheme of connections of the coil and cable
