Hi guys
i have only one problem,i have finished from building TGSL every thing was Ok until this problem,
it's when +12v touch +8v,i mean +12v reach IC 2024 pin14,should change it and other things that have +8v? because this problem what is now not work and must to change it
TESORO GOLDEN SABRE
Be sure include 100pF pin-8 to ground, or it will not be a good thing.
go here http://www.geotech1.com/forums/showthread.php?t=15710Originally posted by apocalypto View Posthi,
please can you give me the last updated documentation of TESORO GOLDEN SABRE, i want build this project.
Cordialy
guys i just want to ask if is there difference between TL071AP and LM308 (U104.U105),both is ok or LM308 is better?
All the information is here ->Originally posted by apocalypto View Posthi,
Cordialy
hi,
Cordialy
Hi guys
just i want to know what's the difference between TGSL and IGSL-TGSL in the depth,i know that TGSL cat detect in air approx 30-34cm,but IGSL-TGSL?
thanks
Originally posted by porkluvr View PostNo apology necessary. It's your doggone creation and you can draw it any way you have to. Ummh by the way, a big thanks to you for the project. A major success.
Him not ApBurg? Well, call me pigliver. Yeah, it was late.
ApBerg + Berenburg = ApBurg
ivconic + Deus = ZERO finds (due constant raining here!
PLAGUE! Damn plague lately! I am prisoned for too long in the house, must go out soon!
Cheers!
No apology necessary. It's your doggone creation and you can draw it any way you have to. Ummh by the way, a big thanks to you for the project. A major success.Originally posted by ivconic View Post
:rotfl:rotfl:rotfl
You are 100% right!
I was the "artist" back than, SORRY!
It was the time when i still learned how to use ExpressSCH...
Sorry again!
Regards!
P.S.
It's ApBerg - not ApBurg!
:rotfl:rotfl:rotfl
Hi
i'm now know everything about TGSL,but i wondering if there any modified on TGSL,i have 7 Jan 2012 Version it is ok?.
thanks
Yes, loops; most probably.Originally posted by ApBerg View PostOr... maybe some of other guys had hidden jammer in his pocket! How about that?
..... a nice square wave..... in low modulating freq.............. can be , a friend made a jammer that mobile phone's din't like... So a jammer if you do not like metaldetectors....can be..
But as you write gound loops can also make you go mad, in a Surf PI adding a extra gound wire for external potentiometers made the surf total unuseble !
Best regards!
Now you know why i made so much pcb versions for TGSL in the past! :rotfl
Jammer is a hell of a gadget... in given situations and under given conditions!
:rotfl:rotfl:rotfl
Sorry for not answering, i just saw that this is addressed to me. (Don't have habit to follow these topics on daily bases lately, too much other things to do...)Originally posted by freedan3d View PostHi Ivconic
I maked tgsl with attach pic version
It sensed a small gold coin under 20cm in air and it was low in my mind
I tried to make a 40cm coil for it but i cant reach 16.5 khz on rx
When i tried to reach 16.5 khz ,its inductance was 4.2 mh and my tgsl componnent was over-heating on 22 ohm resistor in speaker section and it burned
I used 0.25 wire for its.
please help me
Thank you
freedan3d
Small gold ring at ~20cm in air is not that bad result after all.
It is not mandatory you to insist strictly on exact inductances.
4.2 mH yet is too low for TGSL.
40cm coil will not improve nothing at TGSL, Porkluvr is right.
I was most satisfied with 27cm DD as largest for TGSL. 25cm will do also.
Don't expect "meters" with TGSL because it is not designed as that.
Main TGSL advantage is very fine behavior and excellent DISC/GEB features.
But, in case you want to boost it as much as possible; than please visit IGSL topic and see second version with modified TX and TX coil with 1mH inductance. Use that TX on TGSL.
It will need you to make quite different coil and TX setup on it, but it will work just fine with a bit of trimming.
Originally posted by ivconic View PostNice bottle! Promising!
Static load... whatever that may be - most probably yes!
I think such behavior appears due not very well optimised circuitry, some component with greater tolerance, some wrong value, maybe some internal loops (pcb, housing etc...)
It is not rare and it is not strictly related only to hand made detector. I've experienced that even with few originals in the past.
:rotfl:rotfl:rotfl
Best regards!
