TESORO GOLDEN SABRE
  • PartNo Replacement Repl. Mfr Type Additional
    LM308National Semiconductor ยท Operational Amplifiers OP77 Analog Devices
    OP02 Analog Devices
    OPA237SINGLE-SUPPLY OPERATIONAL AMPLIFIERS MicroAmplifier Series Burr-Brown
    Legend: Pin-to-Pin Replacement
    Compatible Equivalent
    Functional Equivalent
    Possible Analogue
    http://www.allxref.com/nsc/lm308.htm
    OP77
    • Originally posted by liekwang View Post
      What is the best replacement for LM308 ic please I do not get the lm308 ic in my country
      this OP07DP I can replace the lm308.
      the thing is, you can not find the lm308 in OP07DP will be able to find it?
      the NTE 938 best seems
      • ?Spikes can I find TL081 does equal the LM308
        • fmnotes
          ?I just can do same TL081 do you think
            Try Believe that temporarily will work, but can in some problems. but yet it can not create a problem..
            • ?I just need to find a replacement for lm308 I have currently TLa081 and ic TL082
                Try it yourself. Evil will not do in the system.
                • Hi Liekwang
                  The TLO81 will replace LM308 and work fine.
                  On some but not all of the TGSL builds we found the LM308 to be a shade more stable when using the machine out in the field but apart from that they work just fine.
                  • ?satdaveuk now I have a problem 22omh resistor near burning me confused 7808 what could cause burning I use mpsa 13 with 0, 8omh 5watt speakers
                    • i need street help
                      i have make following TGSL coil Making and i just get detection 15cm in deep coin size is 23mm in my picture
                      this my coin size http://imageupload.co.uk/files/u8e12b6x610fk19pnrq3.jpg
                      what is my problem or i need use LCR meter to Test The Coil
                      im very tired about make the coil need true help about make the coil
                      i have make 15 set DD coil but Stil can not get 30cm distance scan why why why why
                      what tools i need what is
                      i have buy DD cover bulgarian housing and insert coil to the bulgarian cover still same
                      just detect 15cm full-length
                      • hi Qiaozhi & other friends
                        i have a question ;
                        i don't now what is best?
                        or
                        ivconic schematic in page 209
                        please help me
                        • Originally posted by alonejax View Post
                          i have a question ;
                          or
                          please help me
                          Everything is in the link. That's why it's called "TGSL Complete Details".
                          • Okey
                            Thank you bro
                            • hello
                              please help me.
                              i made this tgsl and work well all metal but disk mode not work. -5v on schematic is -6.2v!
                              what can i do to improve that?
                              • qiazhi
                                ?Where can I find the Board pcb layout top and bottom-side file type JPG TGSL I built the first Board on page 1 and 4 not working always burnt resistor 22omh
