Originally posted by Qiaozhi
View Post
It is possible that you are finding an alternative position for the pots where ferrite is being excluded, because both GEB and DISC channels are active during your tests. However, this would not be the correct ground balance position, and the ALL Metal mode would fail to exclude the ground effect, or even reject the ferrite.
It's true that both channels are used if you listen to the audio beep. Of course if you just observe the output of the GB LM308 for ground balancing, then it doesn't matter what is going on in the DISC channel. And if you start with a disc setting that allows ferrite to beep, then it should be equivalent to ALL METAL mode anyway -- I don't see how it would affect where the GB Syncronous Detector shuts off the GB channel.
Because really the GB channel is just another DISC channel controlled by a separate sync pulse. The two channels are logically combined where the LM308 outputs go into the comparator. Changing to ALL METAL mode does not affect the GB channel at all. A target makes a beep when both channels move positive (output of LM308 ) simultaneously above the sensitivity threshold. So to ground balance, my understanding is you set the GB control just enough to keep ferrite targets under the sensitivity threshold in the GB channel. If you go more, you risk desensitizing or cutting off other targets as well.
So actually, if you set the DISC pot to hear the ferrite beep when you start, then only the GB pot affects where the signal disappears. It will disappear when when the GB channel signal falls below the comparator threshold.
Previously I asked:
what is the initial phase-shift of your coils, and what is the residual voltage after nulling
I would still like to know the answer.
I actually haven't settled on a phase shift, but I think I can get you the approx voltage.
I was trying a phase shift that makes voltages on C15 and C12 non-negative. Then you mentioned that the correct null phase is where the coils have more overlap, so I've been looking at that, since I like the idea of maximum overlap. But I recall that that phase seems to make more negative voltages on C15, C12 there.
In my "workshop" testing, I haven't found any null phase to perform superior to another. And as I've said, it doesn't seem to affect the DISC and GB calibration. But my bench is very crude and noisy and I don't want to jump to conclusions, those are just my findings, supported by the LTSpice sim and theories.
