Im using concentric, above 5cm all medium size iron is not detected, but will detected when very close to the coil
TGSL Tuning & troubleshooting
Because you TGSL is made to detect in the woods lmaoo all jokes aside, id like to know too, as my TGSL its so square wave either, it not saw tooth but is not perfectly square either.Originally posted by Nándor View PostI have built a new TGSL, the Geb circuit makes sawtooth waves instead of square wave. The Disc works fine, I just can't figure out why. If someone has ideas please post.
Hello everyone,
I am a beginner in the field of metal detection, but because I find this project very interesting, I decided to do it. But I didn't take too many steps (I made the coils, the signal generator and the Rx signal amplifier) and I stopped. I don't know:
1. Is there a null signal at the exit U101a-pin7 ? ,
2. Is the output signal processed as phase and / or amplitude?
3. What to look for when checking the floor with Tx, Rx, U101a ? From the adjustment of the position of the coils I obtained a "null" of only 200mV at output of U101a, is it enough?
Thank you for any suggestion.
did you download and study the TGSL 101.pdf document?Originally posted by vas View PostHello everyone,
1-yes. I use RX amp output to measure coil Null and Phase.
2- Both Phase and amplitude are used in DISC mode.
3- 200mV at U101-7 maybe good. Phase is also important and for a DD coil should be about 20 degrees between TX and RX.
Does the TX and RX coils when connected to the TX circuit oscillate at the correct frequencies? This is very important and tells you the coils are correct.
If phase is way off at the Null then adjust the RX Coils C value.
Thank you Waltr,
I promise I will read the pdf document very carefully. These are the signals Tx and U101, pin7. I think I need to change the phase of the Rx coil, right?Attached Files
Hi Waltr,
These is new Tx and U101a pin7 waveform. Is it ok with the phase shift between them? Unfortunately, the voltage at output U101a cannot drop below 200mV a.c.
Thanks again.Attached Files
