Originally posted by simonbaker
This is video from last field test where I tested my pcb with dfbowers coil. My mods include "dfbowers mod" for increased sensitivity range, box enclosure to keep light out, trimming capacitor for RX coil tuning, jumper from audio ground to battery ground to help reduce supply rail pulses.
http://www.youtube.com/watch?v=Z8mVtXH4lKY
Sorry, the video is annoying and not good. I'm just showing it for the record. Traffic and wind noise bad. It's difficult to see where I'm waving the target -- I need a good target holder like dfbowers "merry-go-round" in his basement. The field test is proving difficult to do well. Need better location.
My conclusion is: well, my pcb occasionally can get detection around 30 cm I suppose you can say -- but quite delicate setting of pots. I feel dfbowers gets more consistent, fatter tone in range from 24 to 30 cm. Also, dfbowers has some GB pot setting, my GB pot is at minimum.
It is worth pointing out some differences in my PCB compared to dfbowers PCB, and then pondering which, if any, of these differences matter.
1. dfbowers uses etched PCB as per Ivconic layout. My pcb is hand-wired with 26 gauge buss wire and laid out on a 4.5 by 5.5 board. Possible disadvantages of my board -- higher noise due to spread out; higher buss resistance and coupling of signals such as large audio pulse; more chance of bad solder joints.
Future experiments -- thicker buss wire; change layout to make audio ground next to battery ground; etched board.
2. pot wires - dfbowers has shorter pot/switch wires, particularly disc pot. Possible advantage -- less noise pickup.
3. My pcb has test loops sticking up for probes -- possible disadvantage -- pickup noise.
4. dfbowers has the .1uF bypass capacitors that Ivconic added. I left those off my pcb for simplicity and spacing. Possible disadvantage of my PCB - signal coupling from buss rails to ICs. My feeling is that for the big audio pulse, the small bypass capacitors don't make much difference, but maybe important and maybe reduce motorboating effect.
Future experiments -- add bypass capacitors and assess the difference.
5. dfbowers uses 4.7k resistors, I use 5.1k resistors at front end of LF353. dfbowers may have about 8% higher gain at LF353. Significant? Don't know.
6. dfbowers uses back to back 10uf capacitors for the LM358 filter stage -- I use single non-polar 4.7uF cap. dfbowers has perhaps slightly slower response because of it -- signicant? Hardly seems possible, but...
7. dfbowers uses two transistors for darlington stage of audio amplifier -- I use a single darlington transistor. I don't see a significant difference there, but Ivconic has found the audio stage is very critical to the performance.
8. dfbowers uses two 9 volt batteries in series (18 volts), inside enclosure, for power supply. I use 12 volt AA battery pack external to enclosure, attached by about 9 inch cord. Perhaps my power cord picks up noise? Perhaps resistance of longer cord causes buss coupling? I would think not significant.
9. I have a 22k resistor in the oscillator where dfbowers has a 24k resistor. I could try changing that, but don't expect significant effect.
10. dfbowers I think has resistors to stabilize the unused LM358 op amp as per Ivconic's layout. I chose to stabilize it with a simple wire from the output to inverting input and grounding the non-inverting input, as per some examples I found in a reference. I hope that difference is not significant.
11. I have the "sb mod" (might as well call it that since I'm the only fool who uses it), which is a voltage divider from the oscillator output that feeds a reduced voltage to the discrimination and GB phase shift circuits. The purpose is to get rid of the "jaggie oscillations" in the DISC phase shifter. However, it is possible it introduces a small phase shift of its own (less than 5% probably), and also may reduce the GB phase shift range a little. It also slightly may couple the GB and phase shift pots a little due to the loading effect.
Future experiments -- I can jumper over this voltage divider to assess it's effect.
So some more fool for thought -- I mean food for thought -- to try to find those small critical things that make the TGSL circuit work as well as possible.
Again, as Qiaozhi says, the extra air depth may be of no value. I still want to use it as a basis of comparing PCB construction. Also, it may indicate higher quality of signal at the lower depths also.
-SB
-SB
